Slip clutch won't slip.
   / Slip clutch won't slip. #11
Started a new thread to carry this on.
Old news: Slip clutch on Bush Hog I inherited probably has not been "slipped" in many, many years.
I tried loosening the nuts a couple of turns, still wouldn't slip. I asked about what to do here and got a number of replies similar to: "Rev it up and drop it on an old stump"
I had fear that it was really bound up and I didn't want to risk damaging my tractor PTO. Turns out I was right.
I took it apart today. All 4 fiber discs were corroded and stuck to other parts. I had to use a screw driver to get them separated. I cleaned the metal parts with a chisel, followed by a wire cup brush on an angle grinder.
All 8 bolts were rusted and would not turn with a wrench. The DeWalt impact wrench freed four of them then broke one in half. For the last three, I screwed a nut on and tapped with a hammer while using the impact wrench. I drilled the broken one.
I'll probably replace all 8 bolts. I suspect (hope) the 8 springs are still good. I'll get four new fiber discs (local dealer has them and they are not expensive) and reassemble.
I enjoyed an afternoon of figuring out how things work.
I post this for anyone else that might be in a similar situation. I doubt my clutch would have ever slipped.
Edited for clarity.
Your approach is the only one that has ever worked for me. The last time I found only one or two surfaces could still slip and the other surfaces had bonded hard.
Got the slip clutch back together and the cutter is working well. I thought I had the correct part numbers for the fiber discs. WRONG! So, I took the old ones in and compared. Our local Kubota dealer also deals Bush Hog eqpt. They have a guy in parts that goes out of his way to help. He has even taken the time to explain how to do things to me.
I really like this offset cutter. Leveling it can be a chore. I have to put blocks of wood under the right side so that I can shorten the right lift arm. I'll be looking forward to getting a hydraulic top and tilt to make it easier.
   / Slip clutch won't slip. #13
That does look like a nice bush hog. Our BH SQ 84 twin spindle is 3PH and offset to the right by 9". The leveling part took some trial and error. Ours 3PH A frame that been badly sprung and welded on and a major crack that I did not know about failed yesterday. A guy up the road has some old implements and tractors from time to time. He had a SQ 84 like mine that was broken up from abuse but someone had put a new like A Frame from BH that sells for $400+ so I offered him $400 and he said yes. I do not expect to fix it up but use it for parts since now I have nothing in it so to speak. Everything rotates and has all four blades still on it but the stump jumpers have jumped some major stumps I think. :) The gear boxes seem to rotate fine but are wet on the bottom side so they will need new seals.
Our good one has the shield intact but the one I bought today does not so I may rebuild it for the practice and then label and store it should I need one on the fly some day.
Is your BH totally off set?
Gale, my Bush Hog is 10' wide. My tractor is a little over 6' wide.
The Bush Hog cuts behind the tractor and about 3.5' off the right side.
Makes cutting around the pond and along tree lines much easier.
Year: 2016 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 Door C... (A51692)
Year: 2016 Make...
2019 Chevrolet Silverado 2500 4x4 Extended Cab Knapheide Service Truck (A50323)
2019 Chevrolet...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
New Holland 914A Belly Mower (A50774)
New Holland 914A...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
Swict 78" Bucket (A50121)
Swict 78" Bucket...
