Slip clutch question
/ Slip clutch question #1
EdDekker
New Ipswich, New Hampshire
Kubota B2400, Bobcat 331 Mini-Excavator
My Land Pride 1542 rotary tiller came with a slip clutch (I live in New Hampshire - there is a reason we are called the Granite state). In three years it has never slipped even when I hit a rock big enough to stall the tractor. I found the instructions here to free a slip clutch. I was going to loosen the nuts around the edges and noticed that the number W2300 is on the plastic shield. I can't find a number on the clutch itself. The Walterscheid booklet identifies the 2300 as a 46 HP unit.
I have a Kubota B2400.
Where can I find a number of the clutch on the clutch itself? (The W2300 on the shield may apply to the shield or the wrong shield may have been installed or …)
Will a 46 HP slip clutch ever slip when installed on an 18 HP PTO?
Should the dealer have supplied a different slip clutch?
Ed
/ Slip clutch question #2
<font color=blue>Will a 46 HP slip clutch ever slip when installed on an 18 HP PTO?</font color=blue>
I have shear pins instead of slip clutches on all my implements, but as far as I know, all slip clutches are adjustable (and need re-adjusting periodically or they'll get seized up and won't work). So I think all you need to do is get it freed up, and when you re-adjust it, set it so that it slips a little easier; don't think the dealer would (or should) supply a "different" slip clutch.
Bird
/ Slip clutch question #3
Here is a link to the landpride site. You can down load the owners manual as well as the parts manual for your tiller at no charge.
http://www.landpride.com/lp/manuals/rt_manuals.html
I've got a RTA-2570 tiller last fall and the clutch has only slipped one time in roughly 40-50 hrs of use. It was a piece of railroad tie that did it. But it does till real nice.
Did my biggest field yesterday with it about five acres. Single pass I can do an acre and one half an hour with no problem. Shame is I make more money on the small gardens than the larger ones seems like. Oh well, the tiller is now payed for after the field yesterday.
Gordon
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
1995 TIGERCAT 726 FELLER BUNCHER (A65056)
1995 TIGERCAT 726...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2020 Chevrolet...
Unused 2023 Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
Unused 2023 Del...
PORTER CABLE AIR COMPRESSOR (A67714)
PORTER CABLE AIR...
