Slip clutch needed?
/ Slip clutch needed? #1
DirtHauler
Northern Cali ~~~ "Weed" Country
" '06" Kioti CK30 2015 Mahindra 2555 shuttle 2019 Massey 1760M
I had this thought today after having a problem with a weak "rachet" type clutch on my tiller, being how the CK25/30 "shuttle shift" has a internal "slip clutch" on the PTO, is a slip clutch really needed on the PTO drive line when using an implement such as a tiller?
/ Slip clutch needed? #2
Yes a slip clutch or at least a shear pin is needed on most implements (you definately want one on a tiller)
Your tractor has NO internal slip clutch.
Your PTO has an internal overrunning clutch . An overrunning clutch is locked in one dirrection to run implements, but can rachet the other way when an implement is turned off. (prevents the implement from pushing the tractor ahead through the driveline).
/ Slip clutch needed? #3
Any internal clutching is not designed to replace driveline protection to your machine.
A new slip clutch is not very expensive from agrisupply. I really like slip clutches.
Ummmmm.......I know that my CK20 had an internal over-run clutch but didn't know my CK30 has one being it has a 2 stage clutch. Here's how I kinda found out 'bout this internal slip clutch on my 30 gear drive, a couple of months ago when mowing a field with my rotory mower I happened to run over some old layed down fencing not visible in the high weeds. Well the mower grabbed it, wound it up tight in the blades and locked the mower up, the fence wire was so tough that the tractor broke traction! The wheels was a spinin' but the PTO shaft wasn't turnin'. I pushed the clutch pedal all the way in, disingaged the PTO and after a few minutes of tractor power, was able to free it from the snag. I had to remove the blades from the mower to remove the wire mess! I went and finished the mowing, everything worked fine.
Concerned that maybe something might have gotten damaged, I called my dealer and told him what had happed, he chuckled a little and said not to worry and it was normal for it to slip and they were made that way, so that's where I got my experiance and info from. And yes, I have a new PTO clutch coming
/ Slip clutch needed? #5
Whoa, so do you think it was the main two stage clutch letting the pto shaft slip or an additional bonus clutch in the driveline somewhere?
9008SFL (A64556)
9008SFL (A64556)
2015 HORSE CREEK MFG. FLAT BED TRAILER (A67714)
2015 HORSE CREEK...
2008 SHOP MADE (A68842)
2008 SHOP MADE...
PORTA POTTY (A68842)
FUEL TANK (A68842)
FUEL TANK (A68842)
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
