slip clutch adjustment
   / slip clutch adjustment #1
Michael_S
North East Texas
Kubota L3830
I'll be using by rotary cutter in the next few days for the first time this spring/summer. It has been setting idle for about 7 months. Should I check the adjustment of the slip clutch, and if so, how do i do it?
   / slip clutch adjustment #2
Hi ya
well if it has been shed stored and looked after it should be ok your owner book should tell you how to set your clutch .the plates can get some rust on them tho one way is to strip/clean check plate wear and reset some back the plates off and run for a few seconds to brake the rust and shine the clutch plates then reset i have seen plates that with that much rust and crap in them that they will not slip at all
catch ya
JD Kid
(4) Gladiator 12-16.5 Skid Steer Tires (A50121)
(4) Gladiator...
2015 Ford F-150 4x4 Crew Cab Pickup (A50323)
2015 Ford F-150...
2021 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52141)
2021 FREIGHTLINER...
40' Sea Container (A50774)
40' Sea Container...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
2014 International Durastar 4300 Terex BT2047 47FT 10 Ton Crane Truck (A50323)
2014 International...
