Slip clutch adj
   / Slip clutch adj #1
chliansh
Does anyone have any info on how to properly adjust a slip clutch?
JD 4010 with a JD 647 roto tiller.
I have the manual but no info.
I assume its not adj right after my recent driveline failure.
   / Slip clutch adj #2
There are several threads on "slip clutch adjustment". The one should give you the information you are looking for. Click Here Be sure to read the other post in thread for additional information.
   / Slip clutch adj #3
The reason I adjust/check mine each spring is it can rust up over the winter (it sits outside). Also, when I bought it (new) the clutch was stuck.
I can help you thru it, but you need to know how many ft/lbs it is s'posed to set at.
434669 (A48836)
434669 (A48836)
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
2015 DODGE RAM...
2023 John Deere S780 Combine (A53342)
2023 John Deere...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
2013 VERMEER VACTRON LP555 DT HYDROVAC TRAILER (A52472)
2013 VERMEER...
