Slightly bent FEL - Problem?
   / Slightly bent FEL - Problem? #1
dharris894
NH, ME
Kubota L35
Hello. I am new to the forum but have been studying the posts. What a great source of info!
I am shopping for a 30-40 hp tractor with Loader and backhoe. I found a 1989 L3350 in good shape for $14,000.
However the loader is about an inch higher on one side than the other. I can't tell whats bent. Is it possible that this is something that can't be fixed and should be avoided?
Any other thoughts on this model?
   / Slightly bent FEL - Problem? #2
Did you check the tire pressure? That could affect the level somewhat I think.
Might be sprung and if so, I don't know how you would correct it.
Ron
   / Slightly bent FEL - Problem? #3
It can be a tire pressure differential; especially the rear tires or it can be that it's sprung and can be bent back into the proper place or it can be that it was installed incorrectly. When a loader is installed, all the parts, nuts, and bolts should be assembled loosely with the loader bucket sitting on a hard, level surface (concrete usually), and only after completing the assembly should they be tightened. In any case, I would expect it to be pretty easy to correct.
2239 (A51244)
2239 (A51244)
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A55314)
2021 Unverferth...
Hose Reel (A55787)
Hose Reel (A55787)
