Sliding Glass Door Repair
   / Sliding Glass Door Repair #1
SevenCorners
Charlottesville VA
Jinma 224 2004
I have an old sliding glass door whose seal has gone. The door has a frosty look in between the two glass panels. Can this be fixed? Or can I buy a new "pane" to replace old. All advice appreciated.
   / Sliding Glass Door Repair #2
You have to buy a new pane. AFAIK, the space between the panes of glass is either a vacuum or has some type of gas pumped in. When the seal breaks, 'regular' air leaks in and what you're seeing is the moisture condensing on the inside of the glass.
   / Sliding Glass Door Repair #3
What type of door is it? Wood or aluminum? Some of the aluminum patio doors are not easily repaired & the cost from a glass shop may be prohibitve. The corner keys can be crimped & they tend to break on removal, the replacements may not stay in very well. The wood patio doors are easier, be careful with the glazing bead & it can be re-used.
It is an aluminum sliding glass door, sounds like I could be in for trouble if I want to go the repair route. I priced out a new door $1000 and up, arg I hate to throw stuff away only to buy newer [more expensive] ones.
   / Sliding Glass Door Repair #5
I have been out of the construction business for 5 years , but i believe you can still buy a vinyl sliding door for under $500.00. I would buy vinyl or wood over aluminum.
   / Sliding Glass Door Repair #6
Mine is the same way. Had planned on doing this summer, but, you know how that goes.
I priced a high end Pella for $1200, but some of the lower Pella's were around $700. You can get box store brand for under $400.
   / Sliding Glass Door Repair #7
I couldn't find my glass guy to ask him but I do know this much. The sealed glass in that door will have to ordered as a unit, they don't make them up in a normal shop. There is two pieces of glass, as you already know, and the space in between is purged with argon. At least, that is what I was told. Some of them might use nitrogen, any inert gas that'll force the moisture out would probably work. The expensive part is that they have to use tempered glass in patio doors. That is going to be an expensive unit.
I ran across a handyman site where someone had posted the same question. They advised the poster to call the manufacturer. They said that those doors are supposed to be sealed for life and there is a chance the manufacturer would replace it for free. It's worth a shot.
   / Sliding Glass Door Repair #8
Years ago my weed wacker threw a rock into the sliding glass door. /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif Since it was tembered class it spend a good day or two slowly breaking. /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif
I can't remember the cost but we had a glass company replace the panel for a reasonable price. Certainly was cheaper than a new door. It was and is aluminum.
Later,
Dan
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
2007 GALYEAN 130BBL VAC TRAILER (A53843)
2007 GALYEAN...
2012 Freightliner M2 Chipper Truck (A52377)
2012 Freightliner...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A55302)
2022 New Holland...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A54607)
PEMBERTON...
