Slice in rear tire repair
   / Slice in rear tire repair #1
rongrzywacz
PA - Lycoming co.
ford 2N
Neighbors tractor/loader has a slice in one of his rear ag tires. it is not too deep, can't see any of the cords, but does go through one of the cross lugs.
It is not leaking and the tires are not loaded. Is there anything i can use to seal the slice to keep sharp rocks/dirt out. I probably looks worse than it is but just want to be safe. I've heard of vuncanizing compounds but not sure were i can get them. Can't afford to take off or have a tire repairman come in at this time.. tire is on a 2003 Kubota L4610.
Thanks for any advice!
Ron G.
   / Slice in rear tire repair #2
Gempler's has it.
   / Slice in rear tire repair #3
I have even used a product called "Shoe-Goo" sold at running stores to fill in divots in my tires and it is very durable (and cheap)
Gemplers has a product to do the vulcanizing, but they don't ship it to PA or any nearby states and I don't believe that there products are sold in stores.
   / Slice in rear tire repair #5
if it is the cold vulcanizing cement they show....any good auto parts store will have that. Note: the key is "GOOD" auto parts store....where the people behind the counter know the difference between a spark plug and a dipstick.
My local Auto Value has it on the shelf
   / Slice in rear tire repair #6
personally id just run that tire till it starts going flat an then replace it.
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
2024 John Deere 6120E MFWD Tractor (A53342)
2024 John Deere...
