Sleeve hitch for 2554?
   / Sleeve hitch for 2554?
Wow, thanks guys!
The CC factory hitch does look heavier but it doesn't mount the way I assumed it would. No problem, it's just different than I thought it would be. It's nice that it provides a new fixed hitch point too.
I have welding and fabrication equipment but the problem is always finding small quantities of the needed steel to build anything. Everyone will sell you long lenghts of tubing and large sheets of plate but it's hard to buy small pieces.
Does anyone have the manufacturers P/N for the electric actuators used on either hitch? They also look like their different between the hitches.
Thanks again!
Wow, thanks guys!
Thanks again!
   / Sleeve hitch for 2554? #13
Go to the photo tab and drill down to Other,Cub cadet, page 5. I posted photos of my 2544 with the ebay hitch after I had altered it from the original. Worked out great and I use it often with my aftermarket scraper from lowe's. (AGRA fab or brinley). Not terribly complicated to alter. I have plans for either welded or drilled and bolted which uses the least amount of fabrication equip.
The same page has photos of the CC hitch posted by TODDZ. You can see both. Jerry
   / Sleeve hitch for 2554? #14
   / Sleeve hitch for 2554? #15
<font color="blue">( Go to the photo tab and drill down to Other,Cub cadet, page 5. I posted photos of my 2544 with the ebay hitch after I had altered it from the original. ) </font>
Here is 1OldDawg's Photo Gallery and ToddZ's Photo Gallery
   / Sleeve hitch for 2554? #16
   / Sleeve hitch for 2554? #17
Thanks a lot Gator-
CC you're right, I like the Cub sleeve better, it does look beefier.
   / Sleeve hitch for 2554? #18
Thanks a lot Gator-
   / Sleeve hitch for 2554? #19
The actuator is from Warner Electric. Could not find thier part #. It is 12" O.C. from pin to pin, closed. Extension is 4". Not sure of the lift capacity, it lifts the tiller no sweat. Not sure what the tiller weights but it is one extremely heavy SOB!!! I have Liquid in both front wheels, and two suite case weights up front and with the tiller lifted the unit can still be a little floaty up front.
One thing to take note of, and to think about if you are building your own ... take a look at the mounting location of the stock CC actuator and the aftermarket one. The CC bracket puts the top pin of the actuator quite a bit higher. This in turn puts the entire actuator in a more verticle plain and lifts closer to straight up.
If anyone wants to drive to west Michigan ... come on over and have a look.
Stay tuned for the Hiller/Tator digger I'm fabbing up out of scrounged parts .... should be too cool. /forums/images/graemlins/grin.gif
Hope this helps,
Ed
   / Sleeve hitch for 2554? #20
Hope this helps,
Ed
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59575)
2019 INTERNATIONAL...
Ryobi Drill (A57454)
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
2005 Ford Freestyle Multipurpose Vehicle (MPV), VIN # 1FMZK01175GA19616 (A57453)
2005 Ford...
