Slate tile outdoors---proper sealer?
   / Slate tile outdoors---proper sealer? #1
TractorLegend
Platinum Member
Randle, WA
2012 DK 45HST SE w/ FEL
I have a never ending outdoor deck project. It is a 400~ sq ft deck that 5/4 ext. decking, cement backer board w/ taped and mudded joints, an applied membrane system over that and guaged slate tiles adheres with thinset and grouted joints.
The normal sources say use a waterbased sealer so the stone "breathes"
I like the look of some of these urethane clear sealers like I saw applied on a stamped/ colored concrete slab project.
Can this be used on stone?
I need maximum waterproofing as the drains I have on my deck were installed then reinstalled due to water getting around the outside of the pipe/drain below the deck, its an outdoor deck- uncovered.
Apparently water is absorbed thru slate and is pretty porous.
May have not been the best choice- but it seemed a good solution to covering up some failed/peeling Spantex coating that was existing (Gaco type stuff on decking).
Input from tile/masons or the like appreciated!!
   / Slate tile outdoors---proper sealer? #2
Slate isn't particularly porous as stone goes which is why it's so effective on roofs. Traditionally, grate builders use 3 in 1 oil for finishing slate hearths. It renders it resistant to marking and staining and helps waterproof it. You could also use a cocktail of boiled linseed oil and paraffin, a traditional finish to seal porous clay floor tiles. Whatever you use, best to try a test piece first then if it works ok, slap it on.
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
UNUSED IRANCH EXCAVATOR ATTACHMENT SET (A54757)
UNUSED IRANCH...
2015 Peterbilt 337 Pac-Mac KBF-20H Forestry Grapple Truck (A53422)
2015 Peterbilt 337...
1262 (A50490)
1262 (A50490)
UNUSED 4.5X2X2M GREENHOUSE (A54757)
UNUSED 4.5X2X2M...
