Slate tile outdoors---proper sealer?
   / Slate tile outdoors---proper sealer? #1
TractorLegend
Platinum Member
Randle, WA
2012 DK 45HST SE w/ FEL
I have a never ending outdoor deck project. It is a 400~ sq ft deck that 5/4 ext. decking, cement backer board w/ taped and mudded joints, an applied membrane system over that and guaged slate tiles adheres with thinset and grouted joints.
The normal sources say use a waterbased sealer so the stone "breathes"
I like the look of some of these urethane clear sealers like I saw applied on a stamped/ colored concrete slab project.
Can this be used on stone?
I need maximum waterproofing as the drains I have on my deck were installed then reinstalled due to water getting around the outside of the pipe/drain below the deck, its an outdoor deck- uncovered.
Apparently water is absorbed thru slate and is pretty porous.
May have not been the best choice- but it seemed a good solution to covering up some failed/peeling Spantex coating that was existing (Gaco type stuff on decking).
Input from tile/masons or the like appreciated!!
   / Slate tile outdoors---proper sealer? #2
Slate isn't particularly porous as stone goes which is why it's so effective on roofs. Traditionally, grate builders use 3 in 1 oil for finishing slate hearths. It renders it resistant to marking and staining and helps waterproof it. You could also use a cocktail of boiled linseed oil and paraffin, a traditional finish to seal porous clay floor tiles. Whatever you use, best to try a test piece first then if it works ok, slap it on.
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
FRONTIER MG20F LOT NUMBER 80 (A53084)
FRONTIER MG20F LOT...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A55301)
2006 Magnolia Dry...
Cat TH407C Telehandler (A53472)
Cat TH407C...
