Slack/play in the TC40S/16LA loader bucket settings
   / Slack/play in the TC40S/16LA loader bucket settings #1
nickel plate
CA
2002 New Holland TC40S
2002 TC40S (standard)
16LA 6' loader bucket
When attempting to pick up a small load of dirt on flat ground and setting the bucket in the proper scoop position, the bucket won't hold the set position as it wobbles a bit about the set position. Me off the tractor and gripping the bucket with all my somewhat feeble force it won't react at all as to what happens in the field of usage.
Is it the fault of worn out linkage bearings/bushings or the two hydraulic cylinders?
796 hours, bought new.
   / Slack/play in the TC40S/16LA loader bucket settings #2
What do you mean it wobbles a bit? You mean play in the pins or the cylinders are leaking down?
Exactly-play in the pins or cylinders with no external fluid leakage. Which might it be?
   / Slack/play in the TC40S/16LA loader bucket settings #4
It could be any/all and the quick attach if it has one. The best way to find play is to look for it.
No quick attach connection and no leaks throughout the entire hydraulic hose system/no leaking to see.
O.K. again.
Setting the 16LA bucket in any bucket position it will wobble up down/vacillate as to not hold a true/steady locked in directed joystick bucket position. Rebuild cylinders or bearings/bushings? WTHA?
Pallet Fees (A50774)
KRONE AM 283s HAY CUTTER (A51243)
KRONE AM 283s HAY...
CATERPILLAR 48" QUICK ATTACH FORKS (A51242)
CATERPILLAR 48"...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A52128)
Koyker Loader...
2014 Ford Taurus Sedan (A50324)
2014 Ford Taurus...
UNUSED MOWER KING SSB72 BOX BROOM (A51244)
UNUSED MOWER KING...
