slack in steering
   / slack in steering #1
fig
Thomasville, NC
yanmar 1700
I have a 1700 and there is about a 1/4 to 1/2 turn slack in the steering. While I was flushing the radiator for summer use; I checked the steering system. All rod ends look to be o.k. I noticed under the hood that the steering box has what looks like a set screw of some sort. Will this adjust for any slack? There is great information on this site and figured I would ask the pros before messing with it. Any info would be great!
Newton
   / slack in steering #2
The set screw will take up a little but not much. Sounds like you have a bearings going bad, or the gears inside are getting wore out. I have a complete steering column off a YM2202 that may work but you would also need the steering wheel to. If intrested let me know
   / slack in steering #4
I have had two apart recently and both were beyond repair. I got a rebuilt from one of the dealers on here. After I did that it was painless finishing the job.
   / slack in steering #5
The YM2202 uses a different steering box. I have rebuilt boxs & parts available for your tractor.
2023 BOBCAT T770 SKID STEER (A51246)
2023 BOBCAT T770...
40' CONTAINER (A51248)
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
30ft T/A Boat Trailer (A51694)
30ft T/A Boat...
