Tiller skip the plow?
/ skip the plow? #1
JUBILEE1953
Ohio
MF 1742 TLB - Ford NAA
Can I use a middle buster aka a potato plow to break the ground up. Then go right to the rototiller. Do I even need to run the 2 bottom plow through it?
/ skip the plow? #2
Yes, that will work fine. In fact, plowing (depending on how it is done) will require tilling several times to get everything back to level.
If you have a box scraper with tines (scarifiers) that works very well too and can even work the soil a bit deeper depending on the weight of the scraper, condition of the soil, and how the tines are set. It also doesn't leave deep gouges like a middle buster or plow can do.
A plow's main use is to turn the soil over and bury the foliage to decay and act as fertilizer. Rototilling after plowing will bring some of the foliage back to the top and defeat the purpose.
/ skip the plow? #3
That's why it's a good idea to plow in the fall to let the overturned organic matter decay all winter. Then, in the spring go over with rototiller. The best of both worlds !
/ skip the plow? #4
If you are not starting out with sod, that is the area has been plowed at least once before, I would think your middle buster would be enough.
And if you have a PTO driven tiller (you lucky dog) that should do.
If I were in your situation, with my ground at least, I would just use my home made middle buster (on the right) and make lots and lots of passes. Maybe make a checker board type of plow pattern to begin with. It will take some seat time, but keep you from having to buy that particular implement.
With my tractor in my ground, I can pull this home made middle buster 14" deep.
Your situation may be different.
Good luck
/ skip the plow?
My issue is that I'm not sure if the land has ever been plowed. Rock's and root's etc. might be an issue, and It would be alot less expensive to ruin a middle buster than it would be to damage my 2 bottom plow.
/ skip the plow? #6
The last time I used my rototiller, I did as GWDixon said and ran my box blade scarifers deep then criss crossed and rotot-tilled; worked fine. I haven't used one od our breaking plows in some time, but when I did I finished with a disk and spike tooth harrow.
/ skip the plow? #7
How much grass or weeds etc. is there? My experience with tillers is that grass and vines tend to wrap around them Vs getting chopped up. Like others have said a plow will bury them.
/ skip the plow? #8
IF I WAS ME I WOULD SCRATE THE WEEDS GRASS OFF 1ST THEN GO RITE TO TILLER AND SKIP THE MIDDLE BUSTER
/ skip the plow? #9
^yup, basically that's what we did and it worked out fine. If you cut the grass down it wont wrap around the tines.
/ skip the plow? #10
Yes you can. And if you haven't tilled the ground before, I would recommend it.
/ skip the plow? #11
If you're prepping a new area and got lots of rocks like I do then that would be a great idea.
/ skip the plow? #12
The only reason for a plow is to turn the cover under as has been mentioned. If it is a rocky area or roots I would certainly not use a plow. Like you said a middle buster or shovel is a lot cheaper than a plow. Also it will pull the rocks to the top so you can remove them and then go in with a rototiller and chew it up. the cover will rot a lot quicker when it is chopped. If you do plow make sure that you do not rototill as deep as you plow for at least six months to let the cover rot.
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
UNUSED WOLVERINE PT-16-01C UNIVERAL ATTACHMENT (A62131)
UNUSED WOLVERINE...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
UNUSED WOLVERINE PFF2-13-45W QUICK ATTACH MAST (A62131)
UNUSED WOLVERINE...
2023 RIPPA R360 EXCAVATOR (A62129)
2023 RIPPA R360...
