SkidPro Tree Puller
   / SkidPro Tree Puller #31
I find the trees pull out much easier when the ground is saturated. I am able to lift bigger trees when it is wet -- assuming I can get to them.
   / SkidPro Tree Puller #32
Yep. Springtime is best right after frost goes out. Ground is heaved from frost and roots don't have a tight grip.
   / SkidPro Tree Puller #33
First thoughts are that this tree puller will work well with bigger yaupons but, seems to just cut the smaller stuff, 1" and smaller, wherever you clamp on it.
Sorry to interrupt!
:laughing: :laughing:
When pulling small shrubs I just dig into the ground a little while clamping and grasping a part of the roots. Sometimes it helps from it just breaking off. I guess it sorta holds onto the dirt ball instead of the stem.
That's a nice fit for your LS.
2011 MACK GRANITE HOT OIL (A50854)
2011 MACK GRANITE...
2008 FORD F-750XL SUPER DUTY ASPHALT DISTRIBUTOR T (A51243)
2008 FORD F-750XL...
1991 Cleveland Equipment Trailer (A50514)
1991 Cleveland...
2015 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
2016 Ford F-150 Crew Cab Pickup Truck (A49461)
2016 Ford F-150...
2014 MACK CHU TANDEM AXLE DAY CAB (A51219)
2014 MACK CHU...
