skidhoe
/ skidhoe
this is why i decided to build tracks seems like theres quite a few places i could use them
/ skidhoe #24
they certianly look good
but i cant believe that slick flat metal plates have much traction to them.
/ skidhoe #25
Nice build well done.
How did you build your tracks?
How do you tighten them?
/ skidhoe
i wondered how much traction i would have to . turns out aluminum is super sticky so you have to be carefull turning on a lawn there is not much slip at all ive had the hoe in mud half way up the tracks and a slight push or pull with the boom usually gets you moving again.i was stuck once with it so far but i had one track 5 inches from the top in mud and the other halfway down i could still move but a 125hp tractor was handy . in the slickest mud ive had the tires do about 1 to 2 turns inside the tracks the mud pushes out through the openongs between the tracks and away you go . i have a tightner designed to lift the track up inbetween the tires so far havent needed anything. i made the drawings for the track parts then got them plas cut at a local shop and welded them at my welding shop used a spool gun and 35 thou aluminum wire
.if i have trouble moving around on frozen ground ill make a dozen or so bolt on grousers . the side plates are 1/4 in steel with carrage bolts thanks bob
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
John Deere 4840 Tractor (A66285)
John Deere 4840...
John Deere 7000 4R Wide Planter (A66285)
John Deere 7000 4R...
2017 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A65053)
2017 CATERPILLAR...
2022 EZ-GO ELITE...
(INOP) 36 BLADE DISC HARROW (A64278)
(INOP) 36 BLADE...
