Skid steer vs. tractor for hobby farm use
   / Skid steer vs. tractor for hobby farm use #1
dgeesaman
Harrisburg, PA
New Holland TC45DA
Normally this comparison is apples and oranges, but going down my list of uses this situation is not obvious. 15 acre horse farm. 3 acres wooded, 5 acres pastured, and 7 acres of buildings, drainage, and grass to mow. Long driveway, almost entirely level ground.
All mowing will be done with a dedicated commercial mower.
My chores will be:
- Clear snow in winter (central PA, so some snow but not lots)
- Moving / flipping the muck pile
- Pulling drags around the arenas. Arenas are engineered footing but are somewhat soft so traction needs to be considered.
- Lifting / moving large square hay bales within an 80' x 35' wide storage building. Mixed gravel floor. Hope to stack them 3 high, each one weighs 1000# max.
- The odd chore of moving tree branches, moving cut firewood, pulling small stumps, and pulling a few fenceposts.
- Spreading some stone on the upper driveway every few years.
- Light dragging to break up the manure piles in the pastures.*
* This one is more likely to be done with the mower.
Contrary to many small farms, I will not be cultivating any land or doing serious excavation.
After some consideration including the fact that a good used CUT with a sufficient loader costs $15k+, and a used skid steer is well under $10k and more compact, I'm re-evaluating the skid steer option.
Will a skid steer with a bit of ground clearance be suitable for pulling drags around the rings, or may it get stuck? I'm thinking that one major advantage to the skid steer is handling the big hay bales safely with less access space in the building.
Also, with the compact tractor I was basing the loader capacity assuming I use a bale spear in place of the bucket and using the 500mm offset full height lift capacity. Per recommendations, I'm considering tractors with no less than 1200# rating for this condition. Are the same assumptions valid for the skid steer, or are the lift capacities more robust?
David
   / Skid steer vs. tractor for hobby farm use #2
My vote is for a medium size skidsteer for everything but dragging a harrow. A skidsteer is so much faster then a tractor and can turn around in its own space. There are lots of attachments that can be used on the loader, including a bale spear. There are still plenty of Farmall "A"s and Ford 9N/8N size tractors around that can be had for little money that would pull a harrow just fine. Just my .02cents.
Steve
   / Skid steer vs. tractor for hobby farm use #3
A skid steer for 10k is gonna be rough. I'd get a tractor since they are designed to do everything except work in a barn. You may be able to fit a tractor in it anyway depending on how empty it is.
I'm going to need to drag the rings regularly and a mower won't do it. If the skidsteer won't either, I'll need yet another implement for that like a 4wd UTV. Now there is no cost benefit, but it would be an interesting combination:
Option A: Skidsteer for snow, big bales, loader chores. Mower for mowing. UTV / 4wd golf cart w/ dump bed for dragging rings, hauling stuff around.
Option B: CUT w/ loader for snow, moving big bales around the property, loader chores, dragging rings. Mower for mowing. Used forklift for handling large bales within the utility building. With this option I can put off the forklift until we get into the big bales.
Dave
   / Skid steer vs. tractor for hobby farm use #5
I vote tractor. Skid steers can be a major PITA to work on and if you have to hire it done it is expensive. They get stuck easily and generally tear up the ground pretty good when turning. ALso they are slow as christmas and rough riding as heck.
   / Skid steer vs. tractor for hobby farm use #6
   / Skid steer vs. tractor for hobby farm use #7
I have a skid steer, and several tractors. The skid steer is for digging and for rough trail work. Even for mowing, it's for rough areas, it does an uneven job although maybe a different design cutter would be somewhat better.
As mentioned, a ss really tears up the ground if it is muddy or soft. You wouldn't drag an arena with a ss, you would have to come back with a tractor to smooth it out.
Yes, a ss can maneuver better in tight spots...BUT the visibility to the sides and rear really suck!
Turning over the muck pile? You will need tracks or the ss will just spin and sink in. Tracks again tear up the ground.
For handling heavy loads, a ss is more tippy than a tractor (the ss is short wheel base). Lift capacity may be an issue. Skid steers are rated for lift capacity and tipping capacity. Usually the lift capacity is about 1/3rd the tipping capacity. I doubt that 10k will get you a decent condition bigger ss.
Perhaps you need a "utility" class tractor, not a CUT.
   / Skid steer vs. tractor for hobby farm use #8
As Bob Rooks mentioned, articulated wheel loader or tractor. Some Power Trac models might be appropriate for what you want to do.
Ken
The models I'm considering are Kubota L3240, New Holland TC35D, TC40D. Not sure what class they fall into, but with appropriate rear weights and loader they can all lift 1000# to full height. In any case I will be using a SSQA bucket so that bales will be lifted with a bale spear attachment rather than bucket clip-ons.
David
   / Skid steer vs. tractor for hobby farm use #10
I'd go with a large compact tractor or small utility tractor with 4wd and a loader.
I have both a SS and compact tractor and for most 'chores' around the farm the tractor is a lot easier. It doesn't tear up the ground, is 10x easier to get on and off of and is just more user friendly for a lot of the work you describe. However, in a farm setting the skid loader does excel at work with the forks (visibility is much greater), cleaning out the barns, and stacking hay. That said, I mostly use the skid steer for my construction business for excavating, dirt work and moving building materials, the compact tractor mostly gets used on the farm. For the farm I wouldn't be without a tractor of some sort.
2001 John Deere 670C Motor Grader (RIDE AND DRIVE) (VERY NICE) (A50774)
2001 John Deere...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
JCT SKID STEER QUICK ATTACH AUGER SET (A51243)
JCT SKID STEER...
Crate of New Hydraulic Hoses (A47384)
Crate of New...
SET OF (2) TITAN HI-TRACTION TRACTOR TIRES/WHEELS (A51244)
SET OF (2) TITAN...
FORD TW-10 TRACTOR (A51243)
FORD TW-10 TRACTOR...
