Skid Steer-type quick release buckets
/ Skid Steer-type quick release buckets #1
grwoolf
Austin, TX
I am looking at a L3130 and one of the options is a quick release for the bucket, like a skid steer. I assume this system is compatible with standard skid steer attachments (like bobcat system), correct? I like the idea of popping the bucket off easily without removing the entire fel. I also like the idea of being able to use the additional attachments up front, although many of them require additional hyd (more $). Does anyone have experience with the Kubot system or have an opition on it's durability? I have rented skid steers quite a bit over the last year and have had a couple machines with worn out latches, buckets that popped off etc.
/ Skid Steer-type quick release buckets #2
Rental kind of says it all. Sure they are going to wear but people just don't take care of rentals. I have a LS180 New Holland SS and the latches were still in perfect condition after 595 hours. The front remote option is not all that much extra but it sure makes for a great system. I was only thinking of the QD on my new Kubota for changing FEL attachments but your idea to just drop the bucket to mow is great. I have to try it new time.
Charles
/ Skid Steer-type quick release buckets #3
grwoolf, I bought the QA last year with my tractor unsure whether It would be of any use. I've since bought a good set of adjustable forks and am extremely happy for the QA, actually my forks spend more time on the tractor than my bucket. They are litterally the tools of a thousand uses. The setup I have was built by ATI and is very well built and is skidsteer attachment compatible. I'm glad I have it now. Hope this helps.
/ Skid Steer-type quick release buckets #5
</font><font color="blue" class="small">( your idea to just drop the bucket to mow is great. I have to try it new time. Charles )</font>
Yes, about 15 seconds to do so. I now generally don't worry about taking loader completely off until mid summer; if then. I used to take the loader off every time I used the tractor to mow at all. The QA is great.
My neighbor (who I frequently mention - I wonder if he reads this? /forums/images/graemlins/blush.gif) is extremely hard on his equipment, and his workers are even rougher on the stuff. I've never heard of a failure from them. I consider them the "proving grounds" for me. /forums/images/graemlins/grin.gif
/ Skid Steer-type quick release buckets #6
I would add one more comment for grwoolf's benefit. Although ATI has a great reputation and makes great equipment, the L3130 you're considering has a Kubota option for the skidsteer QA and you definately want to use that. It's a little lighter than the ATI and you're bond to get better integration since it's all coming from Kubota.
Kubota doesn't offer a skidsteer QA for my B3030, so I'm glad the ATI option is there for my situation.
/ Skid Steer-type quick release buckets #7
grwoolf
By all means get the QA adapter. I switch between the bucket/grapple, pallet forks and tree shear frequently. I bought my L3130 with 3 remotes installed - cheaper that way. I have QD blocks installed at the front of the FEL for quick hydraulic changes.
I always drop the front attachment to mow for better visibility and rarely remove the FEL - mostly for tractor service.
I did put some washers under the springs on the Kubota QA to get more latch pressure. I could pop the tree shear off when in reverse in some rare situations.
Vernon
Vernon,
I already have my 3130 priced with the 723 FEL and HD bucket.
Do you know what a decent price would be for the upgrade to the quick connect?
Also, can you educate me on what 'remotes' I need and about what they would cost to get now vs. adding on later? I don't know much about hydraulics, but I would really like a grapple bucket some day.
/ Skid Steer-type quick release buckets #9
It really doesn't matter when you install because it will always be a custom add on. I paid $ 800.00 to have 1 set of remotes added to my FEL. It's a little more then some quotes I heard but they change the joy stick out with a new joy stick that has a built-in trigger switch so I can switch from curl/dump on the FEL to grab/release on the grapple with just a pull of my finger. Sweat system...
/ Skid Steer-type quick release buckets #10
Charles, how about a picture of that replacement knob for the joystick. I also want to get a hydraulic grapple for my B3030.
There was a lot of discussion about the control for a 4-in-1 bucket recently but we've had trouble finding out who makes that knob. I've attached a picture of it. I wonder if it's the same thing you're using.
Here's the Thread that talks about the 4-in-1 bucket and the control for it.
/ Skid Steer-type quick release buckets #11
Yes, I think that's the same knob. I seem to remember them calling it a knob from a Quickie Loader.
How do you like yours.....
Thanks,
Charles
/ Skid Steer-type quick release buckets #12
I haven't had a chance to use it yet, unfortunately. We're still waiting on the FEL. What grapple did you get?
/ Skid Steer-type quick release buckets #13
By all means invest in the Kubota Quick Attach System. I can remember when the Bobcat Company introduced the Bobtach Quick Attach System back in the late '60s. It was a superior system then and now the standard on most compact industrial and ag equipment. Even John Deere has come around on their skidloaders.
If you invest in even one loader attachment, you will be glad you have the quick attach.
OrangeGuy
/ Skid Steer-type quick release buckets #14
Roando
I purchase my grapple from Skid Steer Solutions. Their grapple is made different than most. The lower fingers are hard steel with NO gussets so it doesn't pick up as much dirt. Their top is all one pc and opens real wide. Give them a call and let Rob tell you a little more about the ANB Grapple.
I've been using mine on my Skid Steer Loader and it's a BEAST......
My dealer quoted $390 to upgrade to the quick connect. Does this sound right?
My new total for L3130 with 723 Loader, Upgraded Bucket, R4's, and quick connect is $19,340.
Other add-ons:
72" Box Blade - $495
Canopy - $350
Doc/Filing Fee - $80
I may also get the Kubota insurance because the tractor may not be covered under my homeowners. I'm looking at options at this time.
Total out the door = $20,265
Does this sound like a good deal?
/ Skid Steer-type quick release buckets #17
The number of remotes you need depend on several factors. I preferred having remotes over an electric diverter valve. It is an over all cleaner installation.
On my tractor remote #1 is used for the hydraulic top link. Remote #2 will be used for a hydraulic tilt link (when I add one) or to rotate the tree shear. It is "tee'd" to front and rear. Remote #3 goes to the front and is used to operate the grapple or to operate the shear. It seems a bit elaborate but it works well for me and is worth the extra cost.
Using remote #2 for two functions is easy - just unplug the hoses you don't want pressured.
When I bought last July the 3 remotes cost me $1325 when installed with the tractor make ready. The first one would have been about $650-700.
Vernon
/ Skid Steer-type quick release buckets #18
/ Skid Steer-type quick release buckets #19
But if you have one hand on the steering wheel and on on the joy stick to the FEL where does the third hand come from that is needed to pull the remote lever on the same side as the FEL joy stick. Maybe you have something set up different but if not it would seem to be cumbersome to operate a grapple on the FEL?
Thanks,
Charles
/ Skid Steer-type quick release buckets #20
Vernon,
Do you know of any hydraulic latching mechanism for the Kubota's QA systems??? That would be nice not having to get out of the seat to latch the handles /forums/images/graemlins/laugh.gif.
Bill
Gehl RS5-19 (A62177)
2016 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
(INOP) TIGERCAT 720E FELLER BUNCHER (A64280)
(INOP) TIGERCAT...
2021 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2021 ASV RT-25...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
