skid steer to tractor hyd fittings???
   / skid steer to tractor hyd fittings??? #1
murfdog
clark co. Ind
TC45
I have a tc45 with quick attach bucket. My neighboor has a grapple bucket from skid steer that I can use at any time. After looking at the hyd hose connections they are different than what is on my tractor. Do they make an adaptor or do I need to make a special set of hoses for this?? Thanks for any input.
   / skid steer to tractor hyd fittings??? #3
I'd just get a couple of short hoses with QD's on one end that match your tractor and then matching QD's for the Grapple.
Wedge
Yup, what he wrote...or you can probably make some adapters with some steel nipples if the thread sizes are the same.
   / skid steer to tractor hyd fittings??? #4
I made a set of adapters just for the situation you described. Used a male and female set of flat faced skid steer connectors. With a few adapters, I connected them to a set of standard pioneer type tractor couplers. It is best to connect them directly with adapters rather than a short piece of hose. If you a segment of hose, it is difficult to push connectors together because there is nothing ridge to push against or pull against.
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
1990 Ingersoll Rand 185 Towable Diesel Air Compressor (A52377)
1990 Ingersoll...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
Flooring (A53424)
Flooring (A53424)
20X30 ALL-STEEL CARPORT W/ ENCLOSED SIDEWALLS (A53843)
20X30 ALL-STEEL...
