skid steer tire size and recommendations please.
   / skid steer tire size and recommendations please. #1
leveled
NY
MX5100HST FEL, KX121 MINI X GEHL 6640 Ferris IS3200z Kubota 1100RTV
I just bought a Gehl 6640 skid steer and it has 33 15-16.5 worn well, flotation tires. I am debating which tire size to use. either flotation tire or a 12'' tires for all around use its pretty nice a stout with the big tires. Also tread pattern?
I will be using this machine for grapple work on dirt next season and root removal. I am also considering running tire chain on the current tires for snow this season. I will be plowing snow on gravel.
I have never owned a skid steer before, and have never plowed snow with one. i have a fairly large driveway and parking area and this will be used primary on my gravel sections.
what has been your over all experience as far as plowing snow with one, I have a made up plow blade on quick attach, but i may just use the bucket. or possible buy a snow box next year.
   / skid steer tire size and recommendations please. #2
Well your message got moved to a new forum today, so maybe someone will see it that can answer your questions.
   / skid steer tire size and recommendations please. #3
The big thing on skid steer tires is buy the ones with the heaviest duty sidewall possible. Around here that means $200.00 plus minus per tire vs $100.00 for the economy ones. But you’re forever cutting the side wall or knocking the tire off the rim, 16.5’s don’t have a bead lock.
What is snow?
   / skid steer tire size and recommendations please. #4
I’d put the wide ones back on because you’ll need all the help you can get in wet areas.
   / skid steer tire size and recommendations please. #5
Use the factory recommended size for best performance. --Found that out the hard way!!! Also as said,--HEAVY sidewalls!! thanks; sonny580
KJ 20'x30' Metal Garage (A50121)
KJ 20'x30' Metal...
2014 Freightliner M2 106 Altec DC47T Insulated Derrick Digger Truck (A50323)
2014 Freightliner...
2010 Chevrolet Malibu Passenger Car (A51694)
2010 Chevrolet...
Maverick 3250 Excavator Hammer (A50774)
Maverick 3250...
Toro Workman HDX-D Utility Cart (A50322)
Toro Workman HDX-D...
CFG Industrial MH12RX (A50121)
CFG Industrial...
