Skid Steer Quick Tach on John Deere 410
   / Skid Steer Quick Tach on John Deere 410 #1
Scott Damman
White Lake, Michigan
Toolcat 5600
Just wanted to show a project that I am currently working on. I need a new (used) loader bucket for my 410. The thing has been very abused over the years and is just too far beyond repair to save. So I decided to make a skid steer quick attach. I ordered the Titan brackets and hardware and have been beefing them up and creating space for my bucket flanges to connect.
Its not complete, still need to add 1/2 plate for my bucket flanges to connect to they are 10 wide so wont fit on the 3x4 box tubing.
Im thinking I will add a receiver for a hitch in the middle of the cross piece. Any other function tips are greatly appreciated.
   / Skid Steer Quick Tach on John Deere 410 #2
I used the same quick attach brackets and my mounts ended up close to the pivot for the levers like yours. I would recommend trimming the sides of the levers so that they will go over center. If you do not do this there is a chance they will work loose and the locking pins will unlock.
   / Skid Steer Quick Tach on John Deere 410 #3
You do nice work Scott. You'll be very happy with a QA. I built one for my tractor last year, and I change from bucket to bale spear every day.
The levers do go past center now. How far past center did you find they needed to go? I will get a video tonight showing the current condition I am interested to see what your thoughts are having done this before.
Paul, I am looking forward to being able to switch between implements, I think it will make the tractor much more versatile. Do you have any pictures of your build?
I have a few implements in mind,
Front mount box blade/land plane
I know people have varying opinions on working off the loader but I plan to make a work platform for working on the house.
I have a set of skid steer forks I got used.
I also got a versalift manlift that I plan to make attach to the loader gives me a portable manlift that will reach ~45ft. I will post info on that when I build the mount for it.
Thanks
Scott
   / Skid Steer Quick Tach on John Deere 410 #6
Scott, my pics are at the bottom of this page: Male Skid Steer Plates - Page 2 . I also have plans to build a work platform, except since I don't have pallet forks, it will have it's own QA plate. Possibly safer that way, since it can't slide off the forks. I'm thinking 3' x 5" (or 6") platform with a 3" railing all around. I think it should work good for working on buildings, trimming trees, & picking apples.
   / Skid Steer Quick Tach on John Deere 410 #7
nice job.
   / Skid Steer Quick Tach on John Deere 410 #8
Mine were barely over center. I trimmed it so that the bottom of the handle was flush with the washer and angled up to the top.
Paul, Thank you for sending over the link looks like a strong build. I was thinking about using an attach plate as well seems that it would be a bit safer, but since I have the forks already I might go that route and save a bit $$.
Ok so mine also just barely go past center, sorry I will get a vid. I might need to trim mine as well.
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
2023 CIMC 53X102 REEFER TRAILER (A52576)
2023 CIMC 53X102...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
JCB 409 AGT4 WHEEL LOADER (A51246)
JCB 409 AGT4 WHEEL...
