Skid Steer Mower Width
/ Skid Steer Mower Width #1
nch77
Fordsville, Kentucky
Ford 5610(2)
I'm buying a heavy brush cutter for my Bobcat, a T870 and of the three I've narrowed it down to the only thing I haven't decided is width yet. My Bobcat is about 1" under 7' wide to the outside of the tracks. Is it better to have a cutter that cuts a path wider than the tracks or not? The options for 84" cutters is fairly limited, the CID extreme duty is the one I'm looking at currently.
/ Skid Steer Mower Width #2
Mine is a hair wider than my tracks, I would want one at least as wide as my tracks if weight and hydraulic flow wasn't an issue.
I've got 100 hp and 36 gpm, I'm not too concerned about weight
/ Skid Steer Mower Width #4
the width needs to be wider than the machine tracks, one thing I will say a wider by a foot is great around fence posts and trees
cut width or overall width needs to be wider? I figured 84" cut would let me get close to a fence, or even a 78 since the skid shoes would still be wider than the tracks.
/ Skid Steer Mower Width #6
This 84" is two feet wider than the Toolcat. Makes it good for getting close to stuff:
/ Skid Steer Mower Width #7
I wonder if I could put a wheel on the front of my Bobcat brush hog? Got a 6 ft mower on a 5ft wide 50 hp 773. It is about maxed out.
/ Skid Steer Mower Width #9
I think with a skid steer it could put too much pressure on the wheel unless you put a hinge on the attachment plate like mine has:
/ Skid Steer Mower Width #10
This is my current pick, looks like a good mower
If you are mostly cutting grass I think it's probably a gook pick but if you cut much brush you will be happier with one that has carbide teeth on the bottom of the blade carrier for shredding the debris into much smaller pieces and better demolition of the stumps for a better finished product, that unit won't have any problem cutting the brush as it has a heavy blade carrier which will transfer plenty of momentum but it will leave a lot of large debris. Have you checked out MTL or Rut Manufacturing? Also if you don't mind, what machine are you going to run it with?
This can come with carbide teeth. MTL has some reviews I don't like, though I've looked into the Rut model. I'd be running it on a 2011 Bobcat T870 that has a forestry kit on it.
/ Skid Steer Mower Width #12
10-4 you will really appreciate what the carbide teeth will do with the debris and stumps, I have an MTL and it has been flawless and they were good to work with for me, but I saw a lot of bad reviews about the owner rather than the product, I originally ordered a Terminator XP from Rut but they changed the design of the blade carrier from a round double plate design to a square single plate design which I did not want, but once I questioned them they said it was to keep from having to raise the price and they were good about refunding my deposit, good luck with your purchase, CID has a good name in the skid steer brushcutter market.
/ Skid Steer Mower Width #15
If you put it in float, then it shouldn't put too much pressure on it - I think, somebody correct me if I'm wrong.
/ Skid Steer Mower Width #16
If you can place the boom in float and the and the retract function in float that would work
For that size brush and weed trees you need a mulcher.
/ Skid Steer Mower Width #17
I have owned the 84" CID extreme high flow cutter for a couple years now. Very happy with it. It is a beast of a mower. I have the optional mulching teeth.
do you have the piston motor? three or four blades?
Box of Misc Monitors (A64126)
Box of Misc...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
LANDPRIDE RCR1872 - 6' ROTARY MOWER (A64277)
LANDPRIDE RCR1872...
Crust Buster 15ft. Grain Drill (A65640)
Crust Buster 15ft...
Denyo DCA-600SPK 500kW Sound-Attenuated Diesel Generator (Trailer NOT included) (A63689)
Denyo DCA-600SPK...
1996 International 4700 (A64127)
1996 International...
