Skid steer brush cutter
/ Skid steer brush cutter #1
rickdavis81
Rich Hill, MO
Case 90xt Deere 5105
Starting a new project and been researching and reading forums for tips and advice. I have a case 90xt and am supposed to pick up a Deere 609 brush cutter Monday. Planning on one of surpluscenters pto shaft hydraulic motors and cross over relief. Online it says my loader is rated at 25gpm and 3000psi. Any help on which hydraulic motor would give the proper torque and speed? I’m excited that I found the 609, they’re supposed to be a beast. Not as much as say an mtl meant for a loader but I’ll have a lot less $$ in it.
/ Skid steer brush cutter #2
Surplus Center should have the proper motor.
Are you going to copy this design with the hinged SSQA plate?
And the motor driveline?
Wasn’t planning on a hinged plate. But driveline should be the same. Looking at going with a 9-10 displacement motor. They have a char-Lynn that I’ll probably go with. Looks to be the only one with a high enough gpm, pressure and rpm rating. Also the most expensive, my luck as usual lol
/ Skid steer brush cutter #4
The hinged plate works good on the uneven ground.
It also has an open front with chains:
I could see where it would be with the front wheel. I’m going to remove my wheel and open up the front to expose the blades. It’s more for reclaiming some land then mowing. I’d rather sit on the tractor and drink a beer while mowing then sit in the skid steer lol.
/ Skid steer brush cutter #6
Now they make it with a removable front wheel:
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
2003 International 4300 Flatbed Dump 571559 (A62613)
2003 International...
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
