skid steer brush cutter motor. HELP!!!!!
   / skid steer brush cutter motor. HELP!!!!! #1
pairofhounds
columbus ga
2015 Cat 305
Trying to find out a good direct drive/axial piston hydraulic motor for a heavy duty brush cutter. I have already built one using motor connected to gearbox. Naturally, no manufacturer wants to share this info. I have a bush hog 672 that Id like to put a direct drive motor on. Anyone got some ideas? Hi speed hi torque. 20-30 gpm flow. like the setup in attached photo...
2012 CID skid steer brush cutter | no-reserve auction on Friday, November 15, 2013 |
   / skid steer brush cutter motor. HELP!!!!! #2
I am assuming you looked at the price of the skidsteer.
Just a plain hyd motor with the cu in displacement to provide enough torque will run too slow.
If you look close, that motor is connected to a planetary gear assembly.
It also has a case grain.
That is to up the speed.
A 30 cu in hyd motor using 30 GPM will run at 231 rpm and produce about 14324 in lbs of torque working at 3000 psi.
If you feed that into a gear box, you have to work out the blade rpm and you will also lose some torque.
Any tips to create a comparable unit? The excavator cutter you helped me with works great! Now working on a heavy duty skidsteer unit..
   / skid steer brush cutter motor. HELP!!!!! #4
Tell us what the gear box ratio is and we can compute the blade speed and torque.
It would take about 52 HP to drive that motor to full capacity.
I don't want to use a gearbox. Just like the direct drive in pics
   / skid steer brush cutter motor. HELP!!!!! #6
That is a gear box in the picture.
My educated guess says gearbox.
I could be wrong.
   / skid steer brush cutter motor. HELP!!!!! #8
They are running through a standard gearbox.
On our Power-Trac's brush cutter, they use a direct drive hyd motor.
I believe they use a 3 cu in hyd motor to turn the blades.
The PTO GPM is about 8 GPM, so the speed would be about 616 rpm for blade speed.
A gear box can increase the speed or increase the torque.
The X-treme Brush Cutter does use a piston direct drive hyd motor.
This is a piston hyd motor, and you can bet that they are not cheap.
Eaton - Hydraulics - Motors - Piston Motors - Heavy Duty Piston Motors
3.3in3/rev to 7.6in3/rev, Max speeds to 4500 rpm, Max pressure to 6000 psi.
Here is a small piston hyd motor.
1.89 DYNAPOWER/STRATOPOWER PISTON HYD MOTOR
Ok... so where and what parts do I need? Thanks!
Nevermind. I see your post. Will check
2017 Vactor RamJet Sewer Jetter Trailer (A51691)
2017 Vactor RamJet...
CASE 621G (A53843)
CASE 621G (A53843)
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2015 FREIGHTLINER...
