skid shoes for rear blade
   / skid shoes for rear blade #1
farmerjim
new london county,ct
jd h, jd 50, jd2010,jd 790,case530hoe
i just picked up a rear blade for doing snow removal. i'm planning to add skid shoes like a truck plow, so that when i blade the gravel portion of my driveway it doesn't tear it up very much. i plan to use the mushroom style shoes. has anyone modified theirs w/ skid shoes? just wondering if so what did you use? i have an idea to use some angle iron and sort of copy the design on my dads western plow. any thoughts/ pics may be helpfull are welcome.
   / skid shoes for rear blade #2
I did exactly what you mentioned. I bolted the angle iron on using the outer bolts for the cutting edge. Then I welded a one inch (I think) black iron coupling to the angle iron in a verticle position for the stem of the skid shoe to slide threw. Because I do not change the heigth of the shoes, I used washers for spacers to keep them set. By cutting the angle iron at an angle on the bottom side, I can leave the brackets on all the time(just remove the shoes) and will not effect the use of the back blade with other uses. Sorry I do not have a picture ,but I think you can fugure it out. Hope this helps.
Dan
   / skid shoes for rear blade #3
I made skid shoes for my Landpride RB. I used some 2" ID square tube and 2" OD tube with the holes already punched. I used some scrap 1/4" from an old receiver hitch for the skids. I welded everything together and then drilled the holes in the mounting tubes for height adjustment. I can get the height adjustment very precise by using different diameter pins in the adjustment holes. I use it mainly for scraping snow on my cement driveway. To get it just right so that the blade is held just off of the surface, I currently have 5/16" bolts in the holes. As the skid shoes wear I will put the 3/8" pins back in to raise it up 1/32". It doesn't seem like much but it makes the difference between scraping the snow off completly or leaving a thin layer that turns to ice. For scraping gravel the shoes can easily be raised to whatever height I need. The only thing I would do differently is make the skid larger. It would slide over gravel better if it had more surface area.
   / skid shoes for rear blade #4
square tube setup is nicely done, but you lose the real advantage of the 'shroom shoes ...namely, they rotate and therefore are a lot more compliant ...watch them on a plow as it goes over some uneven base.
   / skid shoes for rear blade #5
Seems like something along the line of moon hubcaps for skids would be ideal, that way the curved part would ride up over obstacles, where a square shoe might catch on something. Looks like they did a nice job though, good job!
   / skid shoes for rear blade #6
While I don't have any experience with skid shoes, I think gage wheels probably work even better.
Here is what I did:
   / skid shoes for rear blade #7
Henro, Good gage wheeels. Is that a 3 spool valve I see mounted high on your ROPS. If it is what is it for. Don't see any T&T.:confused:
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
HYUNDAI 740-9 (A52472)
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
HYSTER H60XT FORKLIFT (A52472)
HYSTER H60XT...
