skid shoes and float positions
   / skid shoes and float positions #1
JrPaul
Northern Md
when i run my front blade for clearing snow how should i have my skid shoes set? should i have them running the cutting blade a inch off the ground or should the blade be set all the way down? wouldn't this negate the skid shoes though, i'm a little confused. Also when i lower the blade should i have it in float position or just lowered to my liking. Half of my driveway is stone the other half is paved
   / skid shoes and float positions #2
For the first snowfall of the season, I used the skid shoes set about an inch below the blade edge. For the second (and larger) snowfall, I set them just a bit lower than the edge. (These are fixed locations - a set of holes in the shoes, not a slot.) Well, for some reason, the leading shoe wouldn't stay in place - the nut wouldn't hold, and it kept digging in. I took both shoes off, and found that I could plow with no problem. I set the toplink for the least aggressive blade angle, and did the finish run with the blade backwards. Concluson? Get lockwashers, a bigger wrench, eat Wheaties or spinach when I want to use the shoes (when the ground isn't frozen solid); when the ground IS frozen solid, I'll definitely take the shoes off. Drive is 800-900 ft. of crushed stone, with a entry of concrete pavers. I have a BX, I think the blade just floats with no position control.
   / skid shoes and float positions #3
I have the "shoes" on my front blade set so the cutting edge is 1/2" off the ground (paved drive). I do run mine in the float position. Not saying this is what you should do but what I have found works best for me. /forums/images/graemlins/smile.gif
   / skid shoes and float positions #4
I don't use skid shoes. On pavement, I tyend to float the bucket and roll it down slightly, to cut. To scrape ice, I crowd rather than float. Sooner or later, I'll actually memorize the location of the tractor stopping cracks. /forums/images/graemlins/blush.gif
On dirt, I roll the bucket back and ride on the heel of the bucket, with the cutting edge about an inch high.
Gravel might be a problem without shoes.
RING 2 STARTS HERE @ 9:15 AM (A58375)
RING 2 STARTS HERE...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
1998 6.5x16 Anderson Utility Trailer (A56859)
1998 6.5x16...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2020 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2020 CATERPILLAR...
