skid shoes and float positions
   / skid shoes and float positions #1
JrPaul
Northern Md
when i run my front blade for clearing snow how should i have my skid shoes set? should i have them running the cutting blade a inch off the ground or should the blade be set all the way down? wouldn't this negate the skid shoes though, i'm a little confused. Also when i lower the blade should i have it in float position or just lowered to my liking. Half of my driveway is stone the other half is paved
   / skid shoes and float positions #2
For the first snowfall of the season, I used the skid shoes set about an inch below the blade edge. For the second (and larger) snowfall, I set them just a bit lower than the edge. (These are fixed locations - a set of holes in the shoes, not a slot.) Well, for some reason, the leading shoe wouldn't stay in place - the nut wouldn't hold, and it kept digging in. I took both shoes off, and found that I could plow with no problem. I set the toplink for the least aggressive blade angle, and did the finish run with the blade backwards. Concluson? Get lockwashers, a bigger wrench, eat Wheaties or spinach when I want to use the shoes (when the ground isn't frozen solid); when the ground IS frozen solid, I'll definitely take the shoes off. Drive is 800-900 ft. of crushed stone, with a entry of concrete pavers. I have a BX, I think the blade just floats with no position control.
   / skid shoes and float positions #3
I have the "shoes" on my front blade set so the cutting edge is 1/2" off the ground (paved drive). I do run mine in the float position. Not saying this is what you should do but what I have found works best for me. /forums/images/graemlins/smile.gif
   / skid shoes and float positions #4
I don't use skid shoes. On pavement, I tyend to float the bucket and roll it down slightly, to cut. To scrape ice, I crowd rather than float. Sooner or later, I'll actually memorize the location of the tractor stopping cracks. /forums/images/graemlins/blush.gif
On dirt, I roll the bucket back and ride on the heel of the bucket, with the cutting edge about an inch high.
Gravel might be a problem without shoes.
Year: 2008 (miles exempt o title) Make: Volkswagen Model: Passat Vehicle Type: Passenger Car (A51694)
Year: 2008 (miles...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A52748)
New Lewis Brothers...
2020 ASV VT70HO Skidloader (RIDE AND DRIVE) (A50774)
2020 ASV VT70HO...
Loegering Metal Tracks (A50774)
Loegering Metal...
