Skid Plates
/ Skid Plates #1
GKThompson
Moneta, Virginia
New Holland TC40DA
I have a New Holland TC40DA. When I am clearing trails with the front loader and rotary cutter, sometimes limbs, etc. have found their way into some of the mechanics on the underside of the tractor. The other day a stick lodged underneath between the transmission pedal linkage, and the only way to stop the tractor from powering forward was to turn of the ignition key. The New Holland dealer says there are no protective skid plates available to install under the tractor to protect linkages, hydraulic hoses, etc. Any solutions? thanks, KT
/ Skid Plates
/ Skid Plates #3
No but I share your pain. I have mashed a hydraulic filter, bent a tie rod, pulled wires apart, and bent metal hoses from clearing debris getting me just right. You will get better at avoiding things but there will always be a sneaky stick.
My bulldozer had a full length belly pan and some members have fitted pans to their tractors. Lots of expensive things under there.
/ Skid Plates #4
/ Skid Plates #5
Several guys here on TBN have made their own skid plates and did great jobs of doing it. Do a search and maybe you can get some ideas.
Farwell
/ Skid Plates #6
Farwell
/ Skid Plates #7
I built my own for the same reason.
/ Skid Plates #8
/ Skid Plates #9
Hi KT,
Here my version for a Kubota BX, if there enought interest, I would be willing to make one for the New Holland for the same price range.
Bird.
/ Skid Plates #10
Hi KT,
Bird.
1997 International 3800 School Bus (A64194)
1997 International...
2016 FORD TRANSIT T350 EL SRW HI ROOF VAN (A67148)
2016 FORD TRANSIT...
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A67148)
2013 CORPUS 40FT...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
