Skid plate for MX5200
   / Skid plate for MX5200 #1
GamblerAcres
Ohio
2018 Kubota MX5200
I'm thinking about mounting a sheet of diamond plate straight across the bottom edge of the loader support arms from side to side, following the contour of the supports. Seems simple and effective enough. If I drill and tap small holes for mounting screws will I compromise the structural integrity of the supports enough to matter?
   / Skid plate for MX5200 #2
Look at the bottom of your trans/rear axle. Usually there are some threaded holes available. Used for factory assembly I'm guessing. Make some brackets that fasten there and then fasten the plate to the brackets.
Small screws won't work if the plate is truly needed. They'll just shear off.
Don't shortcut this process. You'll end up damaging the very things you are trying to protect.
Post some pics when you get started. Advice and ideas are helpful and will be plentiful. :)
   / Skid plate for MX5200 #3
great question. i've damaged some hydraulic lines.
   / Skid plate for MX5200 #4
Sure wish someone sold them, we seem to stay covered up. My brother is finishing up on a restoration of a 69 VW for a friend who looked out after mom in her later years. Those things are getting scarce.
2019 Chevrolet Tahoe SUV (A56859)
2019 Chevrolet...
2012 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A58017)
2012 FREIGHTLINER...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
1996 International Water Truck with a Caterpillar Engine (A56435)
1996 International...
JOHN DEERE HAY CUTTER (A58214)
JOHN DEERE HAY...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
