Sjoy
   / Sjoy #1
sjoy152
Willow City, TX
JD 1050
I own a JD 1050 about which I know nothing! My husband showed me how to run it before he died, but that is just about all I know. I use it on my dirt roads (I have a box blade), and to move dirt, etc., with the front end loader. I have not yet tried to use the shredder as I'm nervous about it.
Anyway, a young family member hooked up a new battery backwards,(my fault as much as his), so I had to get a new alternator. A regulator was suggested as it might be damaged also.
Here is my problem: the operator manual shows me the alternator, but I see no mention of a regulator. I am assuming I HAVE a regulator?? Confused!
Joy
   / Sjoy #2
Generally if you follow the wires from the alternator (generator) they will go to an aluminum box with fins on it about the size of a deck of cards. That is the regulator and it is probably mounted near the fuses.
I could see it being damaged by the battery issue, but I wouldn't suspect the alternator being damaged... but I couldn't say for sure.
Btw... welcome to the forum!
   / Sjoy
Well, I had it checked & it was damaged. The boys said it smoked when they hooked it up! So it was an expensive lesson, but one we won't need to repeat! Thanks for giving me a heads-up as to where the regulator is located
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2012 Volkswagen Jetta Sedan (A53424)
2012 Volkswagen...
KUBOTA L2501 TRACTOR (A54756)
KUBOTA L2501...
2004 Caterpillar 345B Hydraulic Excavator (A53421)
2004 Caterpillar...
(INOP) 2016 AUTOCAR EXPEDITOR GARBAGE TRUCK (A54756)
(INOP) 2016...
