Grading sizing a back blade, help
   / sizing a back blade, help #1
woodlot
NW Wisconsin
NH 1920 w/7308 Loader
I have a ford NH 1920. I need a back blade for diveway maintanace and lite landscaping in sandy soil. Is a 7ft blade to much for my tractor? Thanks.:confused:
   / sizing a back blade, help #2
You should be fine with a 7 ft blade if your tractor is a 4x4 . Loaded rear tires and a front loader would be a plus if doing heavy grading chores .
   / sizing a back blade, help #3
woodlot:
With 32/29PTO HP I would think that if you have a 4X4 tractor you could handle a 84" rear blade for your stated uses (especially if you consider the 1'/5HP "rule" and your stated use requirements). I will admit that my opinions are based on my own attachment research for rear blades for my own 29/23+PTO HP 4X4 tractor. I do not have a rear blade so I may be talking out of my **** pore, but that is the size blade I would be leaning towards if/when I do buy a rear blade for my tractor for light grading and snow removal. Jay
Thanks. I do have 4x4 and a FEL.
   / sizing a back blade, help #5
FWIW, I used to pull a 6 footer with a 16 hp B7100 with FEL. No problems except when the snow was so deep and heavy the angled blade caused the tractor to move sideways instead of the snow.
   / sizing a back blade, help #6
ive got a 6' behind mine.... i have more issues with it moving my rear (no loaded tires) than i do pulling it. 4wd makes a huge diffrance keeping me headed in the direction i want to go....
   / sizing a back blade, help #7
I used to have a 1710 and now have a 2120. I pull a 8' blade behind both with no problems. I think for a 1920 you could easily use either a 7 or 8 foot. I just prefer all 8 foot implements so that they can be angled and still cover my tracks plus some.
Andy
   / sizing a back blade, help #8
I have used a 84" with a 33 engine hp and it worked fine. It was FWA with loader.
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
2012 Ford Escape Limited SUV (A53424)
2012 Ford Escape...
2017 DRAGON ROLL OFF TRAILER (A55745)
2017 DRAGON ROLL...
1973 JEEP RENEGADE (A51247)
1973 JEEP RENEGADE...
2014 Infiniti QX60 SUV (A53424)
2014 Infiniti QX60...
