Grading sizing a back blade, help
   / sizing a back blade, help #1
woodlot
NW Wisconsin
NH 1920 w/7308 Loader
I have a ford NH 1920. I need a back blade for diveway maintanace and lite landscaping in sandy soil. Is a 7ft blade to much for my tractor? Thanks.:confused:
   / sizing a back blade, help #2
You should be fine with a 7 ft blade if your tractor is a 4x4 . Loaded rear tires and a front loader would be a plus if doing heavy grading chores .
   / sizing a back blade, help #3
woodlot:
With 32/29PTO HP I would think that if you have a 4X4 tractor you could handle a 84" rear blade for your stated uses (especially if you consider the 1'/5HP "rule" and your stated use requirements). I will admit that my opinions are based on my own attachment research for rear blades for my own 29/23+PTO HP 4X4 tractor. I do not have a rear blade so I may be talking out of my **** pore, but that is the size blade I would be leaning towards if/when I do buy a rear blade for my tractor for light grading and snow removal. Jay
Thanks. I do have 4x4 and a FEL.
   / sizing a back blade, help #5
FWIW, I used to pull a 6 footer with a 16 hp B7100 with FEL. No problems except when the snow was so deep and heavy the angled blade caused the tractor to move sideways instead of the snow.
   / sizing a back blade, help #6
ive got a 6' behind mine.... i have more issues with it moving my rear (no loaded tires) than i do pulling it. 4wd makes a huge diffrance keeping me headed in the direction i want to go....
   / sizing a back blade, help #7
I used to have a 1710 and now have a 2120. I pull a 8' blade behind both with no problems. I think for a 1920 you could easily use either a 7 or 8 foot. I just prefer all 8 foot implements so that they can be angled and still cover my tracks plus some.
Andy
   / sizing a back blade, help #8
I have used a 84" with a 33 engine hp and it worked fine. It was FWA with loader.
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2023 Spartan RT - HD Zero Turn Mower (A50514)
2023 Spartan RT -...
2018 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2022 LOAD TRAIL 102" X 24' TRAILER (A51243)
2022 LOAD TRAIL...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
2016 Kubota RTV-X1100CR-A (A47384)
2016 Kubota...
