Rotary Cutter Size of rotary cutter for Kubota L3010
   / Size of rotary cutter for Kubota L3010 #1
woodchuckc
Tennessee
Kubota L5030
I have just purchased a new (to me) L3010 and am wondering about what size rotary cutter people have been using with this size tractor. I have been using a pretty heavy 6' cutter (about 850 pounds) behind an M4700 and I'm not sure about using with the 3010. I would be cutting off pasture grass and weeds about 3' tall in grown-up fairly level fields. My guess would be that a 5' hog would be better matched to the 3010, but is anyone using a 6'er?
I am saving in the attachment cookie jar for a 5' tiller (and PHD and cultivater and landscape rake and......), but if I really need to get another cutter to keep from tearing up the tractor I will.
Thanks for the advice!
-Chuck
   / Size of rotary cutter for Kubota L3010 #2
Do have a FEL on the 3010?
If u do or have some front weights it can't hurt to try out the 6' cutter.
U will be under powered but if u go slower that helps.
I ran a 5' behind an L2900 and for most of my mowing I wished I had a 6'.
I have a 6' LP behind my 35D and it works great.
Tim,
Yes, I have a FEL on the tractor, but my R4 tires are not loaded. But with that heavy a cutter sitting that far behind the tractor, it would probably be a good idea to further weight down the front end.
I figured I would need to go slower than I did on the M4700, but I just wanted to make sure that just running the cutter wouldn't tear up the PTO on the tractor or anything. I cut about 40 - 45 acres 3 times a year, and being able to run a 6' cutter instead of a 5' one represents several hours of time a year (besides the fact that I already have the 6' cutter). I guess that being able to run a smaller cutter at a faster ground speed would make up some of this difference, though.
Thanks for your input!
-Chuck
BUYER'S PREMIUM INFO LOT NUMBER 2 (A53084)
BUYER'S PREMIUM...
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
SCAN FOR HAULING AND FINANCING INFORMATION (A52705)
SCAN FOR HAULING...
MINI SKID SDLL50 (A55745)
MINI SKID SDLL50...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
60" EXCAVATOR BUCKET (A52707)
60" EXCAVATOR...
