Mowing size of bush hog
   / size of bush hog #1
sgipson
south mississippi
ford 3600 1974
Have Kubota m5040 and will need to mow approx. 24 acres.
Opinions on size mower, single or batwing type for this size tractor
   / size of bush hog #2
I guess it comes down to what you're cutting, frequency and how much time and money you want to spend. For that tractor and acreage, I would probably go with an 8' twin spindle.
   / size of bush hog #3
With the 5040 I had,I usually pulled a 8ft but also have used a 15ft batwing with it. We talking just grass cutting or what?
   / size of bush hog #4
I pull a 12ft bat-wing with our M5040.
   / size of bush hog #5
I'd feel better pulling a 12' batwing with that tractor than a 15' batwing unless it's never going to get into tall thick stuff. Or an 8' twin spindle as suggested above.
   / size of bush hog #6
If the twin spindle 8' is a rigid deck, the flex wing 12ft will follow the ground better leaving less high spots.
   / size of bush hog #7
Agree with others. 8' twin for a rotary cutter. If kept more like a lawn and done every few weeks, 12' batwing.
One thing to consider is if trailering or transporting is ever gonna be done. It's alot easier to trailer a 8'/3ph cutter than an big batwing
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
2012 GALLEGOS 130 BBL STEEL VACUUM TRAILER (A58214)
2012 GALLEGOS 130...
2008 Ford Taurus SEL Sedan (A55973)
2008 Ford Taurus...
1454 (A57192)
1454 (A57192)
2003 Freightliner FLD 120 Columbia (A56435)
2003 Freightliner...
2014 Freightliner MT55 Step Van (A56858)
2014 Freightliner...
