size of box blade and harrow for jd4520
   / size of box blade and harrow for jd4520 #1
yukonhunter
leroy ny
John deere 5100m, mf1643 cab and kubota bx2370woods bb720x land pride disc and reverse tiller
Looking to get a box balde and disc harrow for my 4520...I have no idea on what sizes to get . And what brand do you guys recommend. Thx
   / size of box blade and harrow for jd4520 #2
I had a JD 4500 for many years. it had less HP than yours does, but it was the same basic machine. I had a medium duty Woods box blade that weighed 600 lbs or a bit more. It would handle that with no problem regardless of the soil conditions. I have no doubt it would have handled a 7' model just as well. The HP won't be an issue for you, but traction might at times. I had the 460 FEL (900 + lbs) and dual 110 lb wheel weights on each side. Even then, it could claw for traction in 2 wheel drive f the box was getting full in loose soil.
I never pulled a disk with it, but I have seen them run them up to 8' wide.
   / size of box blade and harrow for jd4520 #3
I use a 7' box blade with my 4520 and would suggest Rim Guard or full weights for better traction. My box blade weighs 1260 lbs and seems to be a good match for the tractor. I recommend you have topntilt hitch to get the best results. A good pull type disk about 8' with 22" blades such as the 1508 would be the right size imo.
Here are two pics of my tractor and box blade.
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A49461)
1993 Ingersoll...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
TEST BID LOT (A50774)
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A49461)
2017 Ford F-350...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A51039)
New Lewis Brothers...
