Tires Size/Make of BX Rear "Bar" Tires?
   / Size/Make of BX Rear "Bar" Tires? #1
glennmac
Western Connecticut
2003 Kubota L3430
Size/Make of BX Rear \"Bar\" Tires?
I am looking for the size, make and model of the "bar" tires that the BX uses on the rear. Would appreciate it if any of you owners would look and post this info.......The reason I am asking is that I am investigating high flotatation tire alternatives with the proper rolling circumferences for my 2910. I think those rear bar turfs on the BX might work as the front tires on the 2910 if they are the Goodyear Terra Tires that I think they may be.......Thanks.
   / Size/Make of BX Rear "Bar" Tires? #2
Re: Size/Make of BX Rear \"Bar\" Tires?
The make is Maxxis M7515 Power Lug there 4 sizes listed on the site www.maxxis.com check under the industrial catagory.
   / Size/Make of BX Rear "Bar" Tires? #3
................and they are not bar turfs. The tires supplied on the BX are either turf or they are bar as in Ag R1 tires. Yes, they are R1's. There are no bar turfs available standard on the BX or as a Kubota option but maybe some local dealer can fit one out with them. Oh, ditto the above post, they are Maxxis tires. J
   / Size/Make of BX Rear "Bar" Tires? #4
glennmac, the tire size is 26x12.00-12
Bill C
2008 STERLING LT7500 SERIES (A58214)
2008 STERLING...
case 370 glass door never installed (A56436)
case 370 glass...
IRGC40 High-End Mini Golf Cart (A57149)
IRGC40 High-End...
Miller Millermatic 25 Welder, SKU# 907321, S/N MJ260223N, Rated Output-Amperage 200 (A59076)
Miller Millermatic...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
IRanch High-End Electric Tricycle (A57149)
IRanch High-End...
