Single-tine subsoiler with colter wheel?
   / Single-tine subsoiler with colter wheel? #1
MaineFord
Ford 1910
Greetings—
I’m planning to do some keyline plowing/subsoiling on a field on my acreage in Maine.
Yeomans Keyline Plows are too expensive, and I’ve only got a 32 HP tractor, so I’m only going to be able to pull a single shank.
So, I’m looking for a single-shank subsoiler suitable for a Ford 1910.
The ~$300 TSC model would probably work fine and it’s likely I’ll purchase one as I need to start this year and those seem available.
But I’d prefer something that has a colter wheel and otherwise more closely mimics a Yeomans plow.
The attached picture from Ben Law’s excellent book “Woodlander” (U.K.) looks just about perfect.
But… I don’t see anything like it for sale.
Any ideas for ordering one, good implement dealers to talk to, or how to add a colter to a single shank version?
Thank you!
   / Single-tine subsoiler with colter wheel? #2
Ford 1910​
Ford 1910 tractor photo
1983 - 1986
Ten Compact Series
Compact Utility tractor
Shibaura built
1900
Series:171019102110
1920
Production
Distributor:Ford
Manufacturer:Shibaura
Type:Compact Utility tractor
Factory:Japan
Mechanical
Chassis:4x2 2WD ( ?? )
4x4 MFWD 4WD ( ?? )
Ford 1910 Weight
2WD :2980 lbs
1351 kg
4WD :3246 lbs
1472 kg
Ballasted:4250 lbs
1927 kg *
   / Single-tine subsoiler with colter wheel? #3
Pretty light tractor for pulling even a single-shank subsoiler through fairly dry soil.
Is your Ford 2-WD or 4-WD? Are the rear tires inflated with air or liquid filled?
TSC Subsoilers do not have shear-bolt protection. If you hit an underground obstruction there is the possibility of your tractor tipping over backwards. ((Ask me how I know.))
As an alternative, if your Maine soil is not too stoney, consider an All Purpose Plow, which are generally available at farm auctions pretty cheap. Your tractor should be able to pull a four shank or three shank All Purpose Plow.
   / Single-tine subsoiler with colter wheel? #4
Your coulter blade idea is a good one. I have a subsoiler just like the one you are considering. It does the job, up to a point, I sink it to maximum depth to sever invading roots from sequoia trees bordering crop land,any roots over 2 1/2 inches will stop my 33 hp tractor in it’s place. I have never had the front end come up, though I don’t dispute that can happen.
The weakness of it, is that it tears the heck out of the turf, and makes a big mess of decent looking grass, which has to be addressed afterwards.
you might think about getting a used coulter assembly and fabricating
it to fit the subsoiler, or having a shop do it.
Hi, it’s 4wd with filled tires and an FEL on the front, I’ll be working in gravelly loam and Sandy loam with some rocks and mostly away from treeline. Won’t buy anything without shear pins, need a subsoiler to keyline the field. Thank you!
Thank you—may ask my neighboring mechanic to fab a used assembly on. Great to know what to expect Re. roots
(INOP) 2016 FORD F150 XL SINGLE CAB TRUCK (A51406)
(INOP) 2016 FORD...
2021 Ford F-250 Crew Cab Pickup Truck (A55852)
2021 Ford F-250...
BIG BED 4' ROTARY MOWER (A57192)
BIG BED 4' ROTARY...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A53421)
2025 ZWB 59in...
John Deere 7430 Premium (A53317)
John Deere 7430...
