Single remote valve
   / Single remote valve #1
jdwb
Union Springs, Alabama
Mahindra 5530
I am thinking about buying a Mahindra 5530 4 WD with front end loader and am told I needed a single remote valve. Is this for the back hydraulics to use with a hay cutter, rake and/or hay baler?
   / Single remote valve #2
   / Single remote valve #3
When you are working with a little bigger tractor as in the 5530, there are a lot more of the implements that have or can have hydraulics to do some of the adjustments or activation of the implement. I have 3 remotes on two of my tractors and I really need 4 on each one of them. If you do go with some rear remotes and do not go the OEM route, then I too would be installing a 4 valve setup. I believe that with the 5530, Mahindra only offers 2 remotes at the most and pretty pricey. The OEM setup is usually a little nicer & cleaner looking than the aftermarket stuff, but is quite a bit more $$$$. Anyway that you look at it though, it would be nice to have the remote there if you need it. ;)
2015 John Deere 7700A Mower (A52377)
2015 John Deere...
2015 Chevrolet Silverado 3500HD 4x4 Crew Cab Service Truck (A53422)
2015 Chevrolet...
2016 KENWORTH T370 S/A SERVICE TRUCK (A51406)
2016 KENWORTH T370...
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
22ft Rollback Flatbed Body with Winch (A51692)
22ft Rollback...
