Single BX FEL Hyd Cyl
   / Single BX FEL Hyd Cyl #11
The 4' extention just locks into the tubing with one angle iron in front on the bottom and one in back on top, the weight of it keeps it in place. Makes it nice to put on and off, just lift the front by the pulley and off it comes. It attaches to the tubing I put in.
   / Single BX FEL Hyd Cyl #12
I'm sure that the BX loader is designed for that tractor and works great, I was just venting about a backyard wannabe selling to the unsuspecting.
   / Single BX FEL Hyd Cyl #13
Jeepone:
On my BX22 the bucket is great and has taken quite a bit of abuse in it's so-far short life. The bucket is well designed for rigidity, and there is quite a bit of gusseting across the bucket and around the cylinder mount. Remember that the bucket is 48", so the torsional moment against the cylinder is only 24" (half the length). Using 2 cylinders with a properly stiffened structure in this size doesn't buy you much.
If that's your big concern with kubota, go for it.
paul
Thanx guys! Your replies have calmed my concern. Now to move in my house and start "TRACTORING". It been a long time comin'. I'll let you know when my baby is born....<smilin'> I'm sure I'll be a regular on this site. Take care!!
Ken
   / Single BX FEL Hyd Cyl #15
The single cyl workds great. The bucket is very heavy duty and lots of steel where it counts. I have used mine heavily over the last two years, doing things I probably shouldn't have, and I have no twists or anything. I could see this as being a concern if the construction was lighter, but you'll have no problems with the BX design....
   / Single BX FEL Hyd Cyl #16
Actually, I feel the BX FEL is stiffer than the 2410 FEL --for the intended capacity----note exactly what I said. You will find very little flex with the BX FEL. I feel the single center cylinder is a superior design in this size range tractor. It is one of the reasons the BX has such a responsive FEL. I am positive as an owner of both a BX and a 2410 that you are worrying about a non issue and seeing a positive as a negative. J
   / Single BX FEL Hyd Cyl #17
On such a little tractor, I doubt the one cylinder will cause problems. The FEL looks to be very well built, and there is plenty of reinforcement on the bucket. Also, I doubt you would be able to dig into anything with enough force to damage that loader. The BX2200 we have at work was bought only because of its small size for snow plowing in the winter, and we have found that in the summer there are things it just can't do with its limited power. Piles of "loam" (high content of clay) that have sat for years are hard to dig into with the BX, while a larger tractor or backhoe will have no problem. Basically, I'd be worried about the BX loader if the power of the tractor was increased, but the way it is, its a great little tractor, and very well built.
   / Single BX FEL Hyd Cyl #18
2 cylinders will let it twist as much as 1 will.
The 2 cylinder set up is tee'd so excess force isn't
equal, lock one cylinder and other one will do all the
movement.
   / Single BX FEL Hyd Cyl #19
Another thing that makes the BX loader so strong for it's size --check it out next time you look at one----notice how much closer the loader side frames are together when compared to a larger B unit. The BX loader arms are very close to the engine cowl which greatly improves visibility and also makes it very stiff. I wish the B2410 had the same loader arrangment. I think we may be seeing some future B series stuff being tried out on th BX. J
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
JOHN DEERE 1000 GALLON ALUMINUM NURSE TANK (A52708)
JOHN DEERE 1000...
2013 PRIME TIME RV LACROSSE (A58214)
2013 PRIME TIME RV...
