Single bottom plow with out 3 pt hitch ?
   / Single bottom plow with out 3 pt hitch ? #11
Ploughs:
There are many pull behind plows that attach to the drawbar. Yes even modern day ones. Some may even have 10 to 12 plowshares on them which make them incompatible for a three point hitch. Some have two sets of plough shares so the land can be worked in a continuous row and eliminate the Dead Furrow. Each set is angled for a different direction and upon reaching the end of the field they are hydraulicly reversed for the trip back.
The older tractor pull behind had levers the operator could reach to set the depth. To lift the plow out of the ground one front plough wheel had a ratchet attachment activated by a pull that would lift the plow. Another pull and the plough would drop.
Tractors were rated on the number of plough shares they could pull, not on horsepower.
In other cases stationary engines were set up and cable arrangements pulled the plough back and forth.
If you want to see an impressive plough find a picture of an old steam tractor in action.
Egon
Well,
I went back today and I believe it is indeed a sleeve hitch. ( apologies to professor) However I went ahead and bought it any way because I think I can use it with some modification. It does look similar to the David Bradley plow shown at the website Paul linked to but it is longer and a little more substantial. I think if I put the drawbar between my lift arms and atttach the plow to it I can raise it and lower it with my lift arms. The only draw back is the draw bar will rotate as the plow is lifted. I will have to come up with a way to keep the draw bar stationary. I remember seeing a post where some one made something for this purpose so thay could pull a trailer around with their draw bar.
Thanks for the great responses and help.
   / Single bottom plow with out 3 pt hitch ? #13
Remember the flip over factor when putting a drawbar on your 3P lift arms?
Nope. What do you mean ?
2005 Honda Accord LX Sedan (A55853)
2005 Honda Accord...
7033 (A51691)
7033 (A51691)
2018 John Deere 5075E MFWD Tractor (A53485)
2018 John Deere...
(INOP) 2019 KOMATSU D61PX-24 CRAWLER DOZER (A52705)
(INOP) 2019...
2024 Bintelli ActivEV Pulse Electric Cart (A55853)
2024 Bintelli...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
