Single bottom plow, breaking shear pins like it's my job
   / Single bottom plow, breaking shear pins like it's my job #21
The OP had a plow that was useless to him either because it wasn't designed for the OPs task or the shear bolt was not designed correctly. The OP did what many farmers would have done. He took it back to the shop and used what he had so he could go to work. The plow is fine. If he had broken the plow what was he really out? It couldn't perform the task anyway. So he bends something; he has a welder. He can fix it. This talk of damaging the tractor is nonsense. As others have already said most of us have caught something that stahled or spun the wheels.
Props to the OP for getting the job done.
Well, I went out in the rain for the last bit of plowing, crossing my fingers that the plow would take it (clay in the rain is a mess) and it did, like a champ. :) Very happy with the results. It does look like the beam slipped a tiny bit on the 3pt (not sure how to explain it, I'll post it up here with pictures and some pictures of my "repair" when it stops raining) which I assume is because I'm putting more force on the plow and it moved a little bit. Might have to weld that too if the bolts are as tight as they can be.
That was where I was, if I broke it, so be it, I need a new plow. If I didn't break it, I was going to buy a new plow. So, as long as it doesn't break the tractor, or cause the tractor to flip and kill me, I'm not risking a whole lot here.
I guess my question really; yes, I'm running a single bottom on a big tractor. But, when I look at the EA 2 bottom plow, it looks like it has the same shear pin setup, so, I can't see any reason I'd have more luck with that, just break twice as many pins per hr on the tractor. So, who does this kind of setup work for? Sure, I guess if your running in an established field, no rocks, no roots, yeah, it would work fine, but, how many people are running single bottom plows in farm fields? I'd think that a huge percentage on these are sold for people breaking ground for a garden or something like that in virgin soil. And virgin soil is tough, has rocks/roots and is hard to break. So, then I started thinking, maybe it's made for a smaller tractor; which, of course, it is. But, honestly, the pin let go so fast on my tractor, I'd think that even a tractor 1/2 the weight and HP, you'd have to be really careful; it would break it pretty fast too (or at least, I'd think so).
IMHO, this is a case of lawyers getting in the way of sensible design, sure, the plow shouldn't flip your tractor over, but it also shouldn't break a pin when you let it get a sniff of the soil either. But, if you ran this on a small tractor (as it's designed for), and if it was a solid shank, yeah, you probably could really flip the tractor over if you hit something good. And to prevent that, I think EA puts a shear pin that's breaking at "10HP of pull" which someone calculated is the flip force for a subcompact tractor; nothing at all to do with "what will the steel take before it lets go". Anyway, that's my theory, and I'm sticking to it. ;)
   / Single bottom plow, breaking shear pins like it's my job #23
Moldboard Plows are designed to be operated with the right front and right rear tires in a plow furrow. A furrow 8" deep produced by a 16" plow.
If you are scratching just one row I believe all four wheels must be on level ground.
Four wheels on level ground will stress the plow and plow shear bolt in ways for which it was not designed.
You are using a Category I plow. A Cat I plow is designed around 12" of tractor ground clearance. Your tractor has 15.7" of ground clearance.
Plows are very sensitive to "geometry".
   / Single bottom plow, breaking shear pins like it's my job #24
You got your work done, that's good.
Your were not going to hurt your tractor.
A 3 point mounted tillage implement is not going to flip a tractor over unless you manage to fold up the toplink.
The only time I have had plows lighten and start to lift the front has been with semi mounted plows when they got hungup on ledges or in hard plowing,
full mounted sometimes will get a front end light when transporting.
   / Single bottom plow, breaking shear pins like it's my job #25
I saw this over the weekend and discussed it with Ted this morning.
When the plow is properly set up, with the exception of an underground rock or obstruction, the plow should work great with no issues.
The only time we've had reports of pins snapping, as in your case, is when the customer is trying to pull it too fast through the ground.
Virgin, difficult soil amplifies the need to take it slow.
Travis
   / Single bottom plow, breaking shear pins like it's my job #26
I live in the same area of the country as the OP. My soil looks just like his. I had the same issue with a 30hp tractor and a 2-12 plow. Shear pin after shear pin. Dad suggested a hard bolt. I was hesitant due to risks to the plow and tractor. It was comical because every time we discussed it, his only input was 'hard bolt'. Nothing else to say. I finally listened and put a grade 8 bolt in for both shear pins. Like the OP, it made all the difference. Nothing was damaged and the plowing went 10x faster. Maybe it's a red clay thing, but there is NO WAY a soft bolt would last in this stuff.
First off, hats off EA, not only did they post here, but they also followed up by e-mail! I'll be posting pictures of the tractor/plow setup in a bit, it finally stopped raining so I can get out there and see if my plow geometry is way off (which is very well may be).
Kind of laughing at the "hard bolt" response. I can picture asking my neighbor and him providing that as his only input, put exactly that way. No explanation of torque/possible breakage/HP to tine length. Nope, none of that, just "here's what'll work, using the least number of words possible". "Hard bolt". Or, in my case, "weld it". ;)
Yeah, the red clay is rough/nasty stuff to plow. But EA is in this area, and I've seen them plowing red clay with this plow, so, I think it should have taken that. In my case, I think it was a combo of virgin soil (rocks, tree roots, etc), red clay (high load to begin with) and a big tractor that wasn't gonna even slow down if a plow that size hits something underground. To give an idea of how overpowered I was on this plow, the shear pin blew out with less of a "nudge" than I feel in the tractor when backing into an implement to hook up. Now, I'm sure I was hitting harder and the pin just relieved the stress, but it was a "bump" for my tractor, not at all a "stopping short" event, more like "my bush hog just jumped a stump" (another way to describe the butt in seat feel when I broke a pin).
Pictures.
20180312_133124-800x600.jpg20180312_133144-800x600.jpg20180312_133149-800x600.jpg20180312_133215-800x600.jpg20180312_133222_005-800x600.jpg
   / Single bottom plow, breaking shear pins like it's my job #29
Out of curiosity what grade is the original shear bolt?
Mine were grade 3, that's the hardest that's recommended you put in there.
   / Single bottom plow, breaking shear pins like it's my job #31
I just read this thread...I'm glad you found the answer..ie. "get a bigger hammer"...however, looking at your pic (the one with the beautiful Eng. Setter), it looks like you may have been a little overzealous with the width of the plow in relation to the how you have it set up behind the tractor...(ie. looks like the plow maybe needs to be adjusted toward the furrow tire about 3 or so more inches...also did you adjust the level of the plow using about an 8" lift on the non furrow rear wheel? Okay..now, if you want to really get this done good, rake/disk the plowed field, (get it somewhat level).. and replow it at a 90 degree angle..it'll make all the difference in the world...PS: I was raised in the 50s/60s on an 8N Ford and used a Dearborn "Economy" 2 bottom plow on many 10 acre fields.. I've now got a Dearborn 10-8 2btm and a Dearborn 1 bottom plow just sittin' in the weeds, as I also have a 1 btm 16" 1pt fasthitch plow for my '74 Farmall 140. Good luck..I know you're gonna love it now that you have your plow "fixed".
2014 Ford Escape Titanium SUV (A59231)
2014 Ford Escape...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
2018 Forest River Flagstaff Pop Up Trailer (A59231)
2018 Forest River...
2020 DRAGON ESP...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A61306)
2017 Yale GLC050VX...
