Single acting valve
   / Single acting valve #11
I used one of these Hydraforce 12 Volt DC NC Solenoid Valve SV10-22-0-N-00 | Solenoid Valves | Hydraulic Valves | Hydraulics | www.surpluscenter.com
Teed at the trailer coupler, drilled hole in the same mounting bracket and put a coupler with thru wall fitting. ran a hose down to loader return line. The 12 volt valve is also mounted on the same bracket. You do have to pull the wheel off and everything is right there to hook into the return.
Then mount the switch where ever you like.
Now you could use one of these if you don't want to use the 12 volt valve.
Keep in mine I have the BX2660 so this might not be the same.
Kubota BX2230D (A47384)
Kubota BX2230D...
54in Fork Attachment (A55851)
54in Fork...
2008 STOUGHTON TRAILER STOUGHTON TRAILER (A55745)
2008 STOUGHTON...
2006 FORD F-250(INOPERABLE) (A55745)
2006 FORD...
2018 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2018 ALLMAND BROS...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
