Single acting cylinders to double
   / Single acting cylinders to double #1
bdog
Elite Member
Texas
John Deere 6130M
My new to me landpride R2512 12’ batwing shredder has three hydraulic cylinders. One raises and lowers the main deck and the other two raise and lower each wing. All three are t’d together with a single hose going to the tractor. It relies on gravity to lower things.
My tractor has three remotes so I intend to separate the wings from the main lift. That part is simple enough. The hydraulic cylinders look like normal cylinders to me with plugs where the second hoses would go. Is there any reason I couldn’t add additional hoses and make the cylinders double acting so I could have power up and down?
   / Single acting cylinders to double #2
If they were power down would it be able to flex and articulate over uneven terrain?
   / Single acting cylinders to double #3
You have "ONE" hose that does both, raise the cutting height AND raises the wings?
I'd be changing that today. I'd want those functions independent of each other. As for the power down.....why? Gravity will bring the wings down. Also, as "96" above says, it might impede your movement (though you could put them in float). Putting them in float though, still opens the door to bump things and knock it out of float.
I'd think you're adding more complexity where/when it's not needed.
   / Single acting cylinders to double #4
I agree with both replies. You loose the ability for wings to float in order to follow the terrain plus on some 1 way cylinder the extra fitting orifice is for a breather. It's possible cylinder piston seal is designed for pressure in only one direction
   / Single acting cylinders to double #5
I think the cutting height is set mechanically through fixed adjustments. The transport wheels' cylinder works in opposition to the wing cylinders. When pressure is applied to raise the wings, the transport wheels are lowered--Higher riding height. When pressure is released, the wings lower and the transports wheels raise to a preset deck cutting height. At least, that's the way it looks in photos.
New R2512
   / Single acting cylinders to double #6
New R2512
Not that way at all. The wing cylinders don't change the deck height. They fold the wings from/to whatever deck height the lift cylinder is set at.
   / Single acting cylinders to double #7
I didn't say they did. I said the deck MOWING height is set mechanically--Separate from raising or lowering the transport wheels. Look at the photos. The hydraulic lines on the wings are plumbed opposite to the transport wheels. ;)
   / Single acting cylinders to double #8
For the LandPride model Tinhack posted, one hydraulic line goes to all three cylinders.
You set mowing height with collars on the wheel cylinder's rod. When the Hydraulic valve activated, the wheels lift the mower to full height AND fold the wings up. Release the pressure and wings go down and height drops to setting of collars on the lift cylinder rod.
   / Single acting cylinders to double #10
Reptile eh? Well then, you're a crustacean! Take THAT!
:oops:
If you live long enough your typing skills & eyesight will probably fail similar to mine(n)
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51248)
KNOW BEFORE YOU...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
