Single Acting Cylinder on Double Action Valve
/ Single Acting Cylinder on Double Action Valve #1
dieselscout80
South Carolina
New Holland TC45DA
Question my Woods C114 has a cylinder that only has one hose aka single acting (power up and gravity down).
I just got a New Holland factory valve for my TC45DA that did not have a valve from the factory and is spring centered and can power in and out aka double acting.
If I plug a single hydraulic line into that valve, will it allow a single acting cylinder to lower via gravity when the valve control handle in is the spring centered position?
/ Single Acting Cylinder on Double Action Valve #2
So you will move the lever one way to lift. In center position, the cylinder just holds position.
To lower, you would move the lever to the opposite way. However, this will dead head the pump and force the fluid through the relief at max pressure, which can cause heat and damage over time. Ideally you would connect the unused port to the tank.
/ Single Acting Cylinder on Double Action Valve #3
It is really unfortunate that so few valves added to tractors do not have a float position, as that is the best method of "lowering" removing the pressure from a single action cylinder. It also works quite well for allowing hydraulic motors to coast to a stop.
Using your valve will allow the single acting cylinder to retract while held in the opposite way which extends it, it does dead head your pump and makes the pressure relief valve work more than it's nice to. When I use my tractor which does not have a float valve on an implement with a single acting cylinder I will dead head the system till the implement is lowered then every once in a while I'll give it another couple of seconds to try and lower again.
If you have removed your loader and will not be using it while mowing you could run hoses back to the implement from the loader lift circuit which likely has a valve with float.
/ Single Acting Cylinder on Double Action Valve #4
For your existing circumstances, the safest way to lower the implement is to turn the tractor off.
Then use the lever to lower the implement down to the desired position.
Sounds like I need to just get a double acting cylinder. I would want to raise and lower the mower as I cut pastures when I get to tall spots that start to pull down the tractor's rpms and then lower it again while still cutting at speed (say 3.5 mph).
Well I dug the cylinder out and lo and behold it is a double acting cylinder, so I just need another hose and coupler. 😎
Is there a way to change a double acting valve with NO float position, so it has a float position?
/ Single Acting Cylinder on Double Action Valve #8
It's possible but you would need to figure the make and model of the valve so you could source the proper spool with float plus all the parts for the detent mechanism.
This is often very hard to find all those parts.
Thanks
/ Single Acting Cylinder on Double Action Valve #10
Also on some valves the float valve has to be the first in the stack or monoblock. I keep getting irritated on my Branson 8050 that it doesn't have a float on any of the rear remotes.
But it apears the only solution is either replace the three spool rear remote valve $$$$$ or tie one into the power beyond of the main valve or the power beyond of the loader valve and install an additional valve (or two) with float $$.
It would be the first valve that I have and I am getting ready to install on my TC45DA.
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
1995 John Deere 7400 (A60462)
1995 John Deere...
2012 Jeep Compass 4WD SUV (A59231)
2012 Jeep Compass...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
2014 Nissan Rogue SUV (A59231)
2014 Nissan Rogue...
2006 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A60429)
2006 CATERPILLAR...
