Chipper Since we're talking about chippers...
/ Since we're talking about chippers... #21
Re: Since we\'re talking about chippers...
Dave,
Here is a link to an earlier post I made about my bucket forks:
http://www.tractorbynet.com/forums/showflat.php?Cat=&Board=buildit&Number=256552&Forum=buildit&Words=bucket%20forks&Match=And&Searchpage=0&Limit=25&Old=allposts&Main=256134&Search=true#Post256552
A local welder made them from my hand sketch. They cost me $75 for the pair, not including the chain, binders, vinyl tubing, and paint. These other items cost around $65, I didn't have anything lying around to scrounge.
I adapted my design from those I've seen on this board. I modifed mine a little by using flat stock to join the upper and lower channel pieces, using an overlapping joint. All parts can be cut with a chop saw, the joints are easy to weld, and plenty strong. Setting the gap is easy, just use a couple of pieces of wood the same thickness as the bucket edge, clamp the channel halves halves together, weld on the flat stock side pieces, weld on the chain, and you're done.
The JD bucket is ideal to use with this design because the top front edge of the bucket is curled down (the Kubota bucket required some reinforcement of its curled up top edge). The bucket will flex a little when you tighten the binders, but I've picked up some really heavy loads with no harm.
/ Since we're talking about chippers... #22
Thanx, That looks like a great idea. I have to completely clear about 20 acres yet so I have a LOT of burning to do, not to mention selectively thinning another 40 or so. That looks very helpfull. Do you still have the 2210 or did you decide to treade up ? Dave
/ Since we're talking about chippers... #23
Anthony,
If you have a digicam, it would be great if you could post some pics of your land clearing operation that we could learn from. Shots of the land area you're clearing, logs you're dragging, how you're using your 4in1 bucket, burn pile stacking, and so on are all very useful and interesting topics that could generate some good discussion. Thanks.....appreciate it.
...Bob
Thats not a bad idea. I have quite a few shots of the land, brush pile, log pile. I need a few shots of me using the 4in1 bucket. The versatility is amazing. From moving logs, to ripping out saplings and brush, to collecting brush for the pile, it is by far the best "option" for someone who is clearing their own land. As soon as I get some pics of that I will post a thread.
