Bigbear4x4
Has anyone mounted a Sims cab on their BX1500 ? My question is , how do you seal off the shift levers to keep the cold out ? any suggestions ?
Could you just turn the fan around and have it blow warm air into the cab. Back in the day before cabs they did that on large cat dozers. fan pushing dust away from operator in summer and warm air back at the operator in winter.Heres the problem, Kubota wasn't thinking when they put the radiator behind the engine instead of in front so the with the fan mounted in front of the radiator , it pulls air from the cab through any crack inside the cab sucking the hot air from my heater in the cab through the radiator . Piss poor design. if I seal up too tight , engine overheats and theres no place to reroute a path for outside air to the fan......
fan blowing away from engine ? how would this cool down the water and engine ?
cool , interesting ! but will it pull the exhaust into the cab ?
If the fan and radiator are way back in front of the fire wall/ dash then I doubt it would be a problem as is. You must have some restriction coming or going from the radiator that needs to be corrected.I really dont have a good photo but it sticks out about 1" at the front left lower part of cowel. close to the top / but forward of the left front tire. I would almost have to extend it with flex piping all the way to the rear I think
The fan / radiator has a plastic cover kind a thing which forms a tunnel . by flipping the fan , will the vacuum effect still work ? doubt it huh?
