Sims cab on my BX1500
/ Sims cab on my BX1500 #1
Bigbear4x4
Member
Frenchville, Maine, U.S.A.
John Deere 4115
Has anyone mounted a Sims cab on their BX1500 ? My question is , how do you seal off the shift levers to keep the cold out ? any suggestions ?
/ Sims cab on my BX1500 #2
My soft cab is a cover my tractor model but similar. The answer is you don't need it anywhere near air tight to be very comfortable in cold weather. I can look right down to the ground on both sides of the seat but I'm up in the warm air bubble, out of the wind and quite comfortable in winter clothes suitable if I had to step outside to adjust something or hitch onto a log etc. I don't even have a heater but the heat coming of the tractor castings makes it twenty degrees or more warmer then outside the cab. Just not having flying snow slap you in the face is a God send.
/ Sims cab on my BX1500 #3
Take a 1/8" sheet of rubber an cut slots in it with a knife to match you lever positions "front to back" then take off the plastic housing an slide it down over your leavers an sandwich it between the plastic housing an the fender. It wont be 100% sealed but really close.
Heres the problem, Kubota wasn't thinking when they put the radiator behind the engine instead of in front so the with the fan mounted in front of the radiator , it pulls air from the cab through any crack inside the cab sucking the hot air from my heater in the cab through the radiator . Piss poor design. if I seal up too tight , engine overheats and theres no place to reroute a path for outside air to the fan......
/ Sims cab on my BX1500 #6
Could you just turn the fan around and have it blow warm air into the cab. Back in the day before cabs they did that on large cat dozers. fan pushing dust away from operator in summer and warm air back at the operator in winter.
/ Sims cab on my BX1500 #8
fan blowing away from engine ? how would this cool down the water and engine ?
The air flowing over the block accomplishes little to nothing. It makes no difference if the air is pushed through or sucked through the radiator as long as the air passes between the coolant filled fins and the metal zigzag strips between them. On a car the radiator is usually on the front where once the car is moving over twenty miles an hour the fan is not needed. A tractor or Dozer moving much slower needs the fan all the time to keep air moving through the radiator.
Have you ever seen a BX1500 engine set up , up close ? Honestly don't think they built this with " winter conditions " in mind. If I completely seal off the cab behind the battery than No cold air or snow will blow in through cracks. and I can run the heater on low and without a coat on at -25 F. no problem at all but as soon as I engage my rear pto blower , within 5 minutes my temp gauge starts creeping up to close to the red line at which time i stop the blower and just use the FEL. Frustrating as ****
/ Sims cab on my BX1500 #11
cool , interesting ! but will it pull the exhaust into the cab ?
No I haven't seen a BX 1500 up close. It would depend on where the end of the exhaust pipe is. Might need to extend it which shouldn't be hard. Can you post a pic with the hood up showing the layout?
I really dont have a good photo but it sticks out about 1" at the front left lower part of cowel. close to the top / but forward of the left front tire. I would almost have to extend it with flex piping all the way to the rear I think
/ Sims cab on my BX1500 #14
If the fan and radiator are way back in front of the fire wall/ dash then I doubt it would be a problem as is. You must have some restriction coming or going from the radiator that needs to be corrected.
/ Sims cab on my BX1500 #15
/ Sims cab on my BX1500 #16
Ah just looked at a BX1500 pic on tractor house. There isn't any way back to it is there? " I see said the blind man"
Frustrating, Tractor works great besides that but living in Northern Maine, being disabled, having a tractor without a cab and heat just isnt gonna work !!! Probably should have bought a Deere. lol
The fan / radiator has a plastic cover kind a thing which forms a tunnel . by flipping the fan , will the vacuum effect still work ? doubt it huh?
/ Sims cab on my BX1500 #20
Hi Several years ago someone said Kub makes a reverse flow fan blade for the bx series think messick said price was apx $45 you mighttry a search or call M. WIsh I could find now
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2014 Ram 1500 4x4...
2013 Ford E-350 Cargo Van (A59230)
2013 Ford E-350...
iDrive TDS-2010H...
15200 (A56857)
15200 (A56857)
Chevrolet Silverado 1500 (A60352)
Chevrolet...
