Simplicity Regent Torsion bar - need front hanger info
   / Simplicity Regent Torsion bar - need front hanger info #1
kenmbz
Super Star Member
S.E. PA
Massey Ferguson GC1720/JD x360/Echo CS-490/CS-620
On my Regent the torsion bar and front hanger are worn.
I was able to get a newish torsion bar, the hangers that hold it on look good.
There is a plate at the front of the transmission assembly that hold the front of the torsion bar. a plate rolled with hooked metal to hold the bar but allow it to flex.
I can't find this in the parts books or see it in any manuals.
Anyone have an idea what it's called, part number etc.
   / Simplicity Regent Torsion bar - need front hanger info #2
It's part of or a transmission mount if I recall. But you really could post some model numbers.
Mfg. No: 1692354 Regent 14HP Hydro.
Thanks tomplum
   / Simplicity Regent Torsion bar - need front hanger info #4
Pick a part, any part...
That is showing only the mower deck carrier. I went through the parts diagrams and no torsion bar carrier, only the mounts for the back.
   / Simplicity Regent Torsion bar - need front hanger info #6
I don't see many Simplicity riders. Isn't the carrier in that above diagram what surrounds the transaxle?
Here is a drive related image:
   / Simplicity Regent Torsion bar - need front hanger info #7
A photo of the part in question would be a big help.
Richard
Simplicity is behind tractor and it's been raining here, pictures as soon I can.
The parts there are the back mounts for the torsion bar. Where the ends go.
The part I am looking for carries the bar in front, Like a hangar.
Sadly, it looks like part of the frame side rails. I guess weld would be the only way to fix.
This is my spare parts machine, the one I use to mow is better, but not by a while lot.
Was hoping to give this to the kid for a runabout as we did the head gasket and valves and got it running real nice...
   / Simplicity Regent Torsion bar - need front hanger info #10
I would think that you could also bolt on a support, not knowing if you weld or not. the first thing comes to mind are the deck supports for the small Toro ZTRs.
2019 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
2023 CORAS PREDATOR 28FT DUMP TRAILER (A58018)
2023 CORAS...
2020 Steiner 450 Slope Mower (A57453)
2020 Steiner 450...
jet ski trailer (A56859)
jet ski trailer...
2017 Ford (A55973)
2017 Ford (A55973)
Sundowner Rancher Express 20FT Livestock Trailer (A56435)
Sundowner Rancher...
