simplicity legacy xl lawn tractor
   / simplicity legacy xl lawn tractor #1
rivernut007
simplicity legacy model # 2690344
I have a 2005 simplicity legacy xl lawn tractor & had the front end loader loaded & bucket would not go up but would go down & the bucket would tilt slowly . I also lost power steering. I changed hydraulic filter & fluid but did not solve the problem. There are 4 possible solutions all of which are very expensive items. Any help narrowing it down
   / simplicity legacy xl lawn tractor #2
First suggestion is get service manual or a known good copy of the hydraulic schematic for your tractor. Then start performing diagnostic work based on the circuit. Example do I have pressure or flow at point A. If yes then check point B. Without a schematic or circuit diagram I would be guessing at possible causes since I am not familiar with the simplicity circuit.
Example of some questions:
Does one pump do everything?
If separate pump for steering vs loader what is common that would make both circuits fail?
Did it fail suddenly or slowly?
Was loader recently removed and installed? If yes are the hoses connected correctly?
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
Ryobi Sliding Miter Saw (A48837)
Ryobi Sliding...
2001 Ford Excursion Limited SUV (A48082)
2001 Ford...
1986 Toyota Pickup Pickup Truck, VIN # JT4RN67S8G5041038 (A48836)
1986 Toyota Pickup...
NEW HOLLAND TV6070 TRACTOR (A50459)
NEW HOLLAND TV6070...
9037 (A48837)
9037 (A48837)
