Simplicity Legacy keeps blowing PTO Switch
   / Simplicity Legacy keeps blowing PTO Switch #1
fluffers
nh
none
Guys I have blown two PTO switches on my 25HP legacy-It works for a few minutes then the switch goes bad- Any ideas??- thks
   / Simplicity Legacy keeps blowing PTO Switch #2
Electro magnetic clutch. -- That probably means a solenoid. This solenoid may have 2 coils; a pull in, and a hold. Both work to move the mechanism but one shuts off afterward. The "hold" coil draws little current. Maybe youre not getting full movement, leaving BOTH coils activated. The switch is probably sized for only a momentary heavy draw and thus overheats and fails. 🤔
   / Simplicity Legacy keeps blowing PTO Switch #3
Not that type of clutch. The clutch used on mower is only a electromagnet hold. No solenoid, no fancy wiring. Just an electric coil that when 12V is applied creates a magnet to engage the clutch.
To the OP take a ohm meter and check the resistance of the clutch. Should be in the ballpark of 2.3-3.3 ohms. Also could be shorting out after it gets hot. Also make sure there isn't a faulty clamping diode in the wiring above the clutch that could be causing an overload issue burning out the switches.
The clutch should only pull around 3-5 amps when operating. But if the coil is shorting out can approach 20 amps without blowing fuses but will damage other electric components.
   / Simplicity Legacy keeps blowing PTO Switch #4
With the power connector to the clutch coil disconnected, check the coil to ground resistance. It should be in the millions of ohms.
If it is shorted to ground, it will cause excessive current flow.
Richard
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
Deere 333G (A53317)
Deere 333G (A53317)
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2006 Chevrolet Impala Sedan (A54815)
2006 Chevrolet...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A55315)
Mahindra 4550-4L...
